Solid or Rubber or a Mix.. #1645777
07/12/14 10:19 PM
07/12/14 10:19 PM
Maryville tn
67coronetman Offline OP
Maryville tn
Curious Has anyone like solid mounts for a street car or a combo of one solid & one rubber i was very curious what all you have to say.
Old car are me......
Re: Solid or Rubber or a Mix.. [Re: 67coronetman] #1645778
07/12/14 10:21 PM
07/12/14 10:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I like solid on the driver's side & OE on the other.
No vibration issues & I will never break one.
Re: Solid or Rubber or a Mix.. [Re: Alaskan_TA] #1645779
07/12/14 10:40 PM
07/12/14 10:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run Poly mounts on both sides and the trans mount.For the 62 413 and 65 440 all came from Imperial services.Both have been beat on and street driven.I dont see much difference in vibration.With them I dont tear rubber mounts like I used to.Rocky
Chrysler Firepower
Re: Solid or Rubber or a Mix.. [Re: 67coronetman] #1645780
07/12/14 11:23 PM
07/12/14 11:23 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Mix them is fine but dont go solid on everything.
Re: Solid or Rubber or a Mix.. [Re: Sport440] #1645781
07/13/14 01:39 AM
07/13/14 01:39 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
All solid felt like being in a dragster at every stoplight. The whole car hummed with the resonating tone of screws and bolts slowly backing out and everything not bolted down jiggled a little. On the power (stick shift) it felt so responsive and amazing, but totally not worth the hassle.
Stock/stock feels and works great for a few months until I put it in reverse and let out the clutch and the stick shift rocks sideways three inches- ripped another one!
Bolt- thru mag mount on driver's side worked great for about 6 months so far but I ripped another PS stocker.
I'm torn between going all poly-lock and 1/2 solid 1/2 bolt thru. I think I'll try one solid first because it's free, but I suspect I should just get the polys, especially since my driveline's pulled right now.
Re: Solid or Rubber or a Mix.. [Re: radar] #1645782
07/13/14 03:25 AM
07/13/14 03:25 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Definitely not a solid trans mount. On a stick car, adding a travel limiter helps with powershifting. Any solid mount will transmit more vibration than a soft mount will. Most important is to stiffen/restrict left engine mount, as the motor's trying to pull up on it under power.
Re: Solid or Rubber or a Mix.. [Re: 67coronetman] #1645783
07/13/14 01:10 PM
07/13/14 01:10 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Personally, I run rubber engine mounts and a poly tranny mount on all my cars and have for many years. But I also run a turn buckle or torque strap on the driver's side.
Best of both worlds; less vibration and chance of breakage along with a good margin of safety.
Master, again and still
Re: Solid or Rubber or a Mix.. [Re: DaveRS23] #1645784
07/13/14 04:58 PM
07/13/14 04:58 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
By solid, we are talking steel or aluminum I guess? I see some of you speak of poly ones, but that isn't what you mean by solid, right?
Facts are stubborn things.
Re: Solid or Rubber or a Mix.. [Re: larrymopar360] #1645785
07/13/14 05:14 PM
07/13/14 05:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Solid mounts are steel.
Re: Solid or Rubber or a Mix.. [Re: Alaskan_TA] #1645786
07/13/14 06:34 PM
07/13/14 06:34 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, thanks. I had found on one car of mine that the poly trans mount transmitted more vibration than the poly engine mounts, and the vibration was from the engine, not the transmission. First I put the rubber engine mounts back, and not much difference. But when I put the rubber trans mount back in the vibration was cut in half.
From now on, only internally balanced 360's for me, but that's a different thread.
Re: Solid or Rubber or a Mix.. [Re: larrymopar360] #1645787
07/13/14 06:48 PM
07/13/14 06:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a solid steel mount on the drivers side and the stock rubber mount on the pass side. It works good for me as it does not cause alot of vibration and works good when I go racing. I drive it alot on the street and I am glad I went this way as it seems to work good for the street and racing. Ron
Re: Solid or Rubber or a Mix.. [Re: 383man] #1645788
07/13/14 07:51 PM
07/13/14 07:51 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I ran stock rubber motor mounts on my 440, but I also chained down the driver's side.
Re: Solid or Rubber or a Mix.. [Re: JoesMopar] #1645789
07/13/14 10:48 PM
07/13/14 10:48 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
solids for me, but it does raise the engine higher, my shaker pokes up a bit more..and that pure muscle car feel is all there...
Re: Solid or Rubber or a Mix.. [Re: JoesMopar] #1645790
07/13/14 10:58 PM
07/13/14 10:58 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Just a little food for thought.
If you use a solid mount on the driverside and a rubber or poly mount on the passenger it will provide a fairly solid mount. I did it for years.
BUT, (just a thought, open to alternatives) now when the motor vibrates/moves, it is flexing the block at the mounting tabs for the solid mount. Under hard acceleration, couldn't it even pull the #3 cylinder walls slightly out of round? After all a properly done hone job includes using a boring plate to simulate the load of the cylinder head bolt stress.
Seems like most of my motor failures when I ran a solid mount, involved bearing issues at the 3-4 journals.
So I would recommend the poly mounts with the use of a travel limiter (chain, cable, turnbuckle, ect..) connected from the frame to a head or water pump bolt.
Re: Solid or Rubber or a Mix.. [Re: ProStDodge] #1645791
07/14/14 09:40 AM
07/14/14 09:40 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Schumaker(sp) makes a mount that has poly with steel inside sort of an L from the top to inside of the poly. I have one and it works great no Vibration
Re: Solid or Rubber or a Mix.. [Re: babarracuda] #1645792
07/14/14 12:01 PM
07/14/14 12:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
here is where the spool later kinds are a wonderfull setup!!
Re: Solid or Rubber or a Mix.. [Re: babarracuda] #1645793
07/14/14 05:43 PM
07/14/14 05:43 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Gonna have to disagree with you here..
Went from India rubber stock ones ( Engine movement with the hood up in reverse was truly scary) to Shumacher Mtr mounts.. Definitely more vibration felt in my pic car.. Stock 440/727..
