Sealed Up Carb to Scoop.... #1644777
07/10/14 12:14 AM
07/10/14 12:14 AM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
I whipped up an air pan to seal the Carb to the hood. It seals up real nice. I even blocked off the back of the scoop, so the only place the air can go is down the carb. Anyone see anything that may cause me problems?
Also, I ran a string from the front of hood to the roof to see where the scoop opening lies, it's above that line, if that means anything.
Re: Sealed Up Carb to Scoop.... [Re: STEFF] #1644778
07/10/14 12:21 AM
07/10/14 12:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like it'll work nice... I see you did the old
string trick
Re: Sealed Up Carb to Scoop.... [Re: MR_P_BODY] #1644779
07/10/14 12:44 AM
07/10/14 12:44 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Looks nice and should be very effective
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Sealed Up Carb to Scoop.... [Re: B3422W5] #1644780
07/10/14 06:45 AM
07/10/14 06:45 AM
gregsdart Offline
gregsdart  Offline
Nice work there. I don't know how effective it would be, but will offer a couple of thoughts. You might see some difference if the back of the scoop was unplugged. It all depends on whether the scoop is above the boundary layer coming off the front of the car, and if the air entry is smooth enough for max air flow. The back block off could be run open, holes in it, or screened, to modify the way the air moves around inside the scoop , hopefully to make it as calm as the airflow can be. I used an air cleaner base riveted to the air pan to help this. I also have a very large air filter made out of door screen to keep the bigger rocks out, and maybe keep the turbulence down around the carb inlet. One way to find out how effective your system is would be to build a system for testing that would run without the hood, but incorporate what ever you figure may improve or help air flow. air bell, taller scoop, 14x 6 inch K&N filter, (I just bought one, going on shortly!)
By the way, K&N makes a pretty big rectangular 2 1/2 inch tall filter that just might fit inside your scoop. It has 180 square inches of filter area, which is supposed to flow enough to take care of about 800 hp. They have a formula on their web sight to figure it out.
Re: Sealed Up Carb to Scoop.... [Re: gregsdart] #1644781
07/10/14 05:19 PM
07/10/14 05:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My scoop was turbulent crazy like till I put some teardrop holes in the back and it`s a 6-pack scoop sealed and is definately pullin in air cos it`s trying to rip it off even at slow 45 mph speeds. I did the string deal also and ideally they say you want the opening ABOVE the string but mines a bit less than 1/2 way..........
Re: Sealed Up Carb to Scoop.... [Re: STEFF] #1644782
07/10/14 05:39 PM
07/10/14 05:39 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Looks real nice!
2 kids and a dog
Re: Sealed Up Carb to Scoop.... [Re: TonyS451] #1644783
07/10/14 05:44 PM
07/10/14 05:44 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice work as always Steff
Gotta be worth a least 3 or 4 tenths
Re: Sealed Up Carb to Scoop.... [Re: 340RICK] #1644784
07/10/14 05:49 PM
07/10/14 05:49 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Don't overlook connecting the bowl vents with a piece of tubing.
The little old lady from Pasadena is back!
Re: Sealed Up Carb to Scoop.... [Re: Barnstorm] #1644785
07/10/14 06:03 PM
07/10/14 06:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good point.............
Re: Sealed Up Carb to Scoop.... [Re: MR_P_BODY] #1644786
07/10/14 07:43 PM
07/10/14 07:43 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Can I get a play by play on the string trick? Not familiar with it
Re: Sealed Up Carb to Scoop.... [Re: SpareParts] #1644787
07/10/14 07:46 PM
07/10/14 07:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You run a string from the ft. of the hood up to the roof line and apparently would like the scoop opening above that idealy.......
Re: Sealed Up Carb to Scoop.... [Re: Thumperdart] #1644788
07/10/14 08:00 PM
07/10/14 08:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You want the BOTTOM of the scoop inlet above the string
Re: Sealed Up Carb to Scoop.... [Re: MR_P_BODY] #1644789
07/11/14 12:22 PM
07/11/14 12:22 PM
Renton Washington
Triple Threat Offline
Renton Washington
Have you taken it to the track yet? Curious to hear what it runs!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Sealed Up Carb to Scoop.... [Re: Triple Threat] #1644790
07/11/14 12:46 PM
07/11/14 12:46 PM
STEFF Offline OP
STEFF  Offline OP
I've been out twice, with issues that netted no real results. I'm hoping to get out tonite for some T & T, if the weather holds up.
Re: Sealed Up Carb to Scoop.... [Re: STEFF] #1644791
07/11/14 12:58 PM
07/11/14 12:58 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
looks like it should work great and now that's its made you can actually test it and give us feedback
Re: Sealed Up Carb to Scoop.... [Re: sixpackgut] #1644792
07/11/14 01:01 PM
07/11/14 01:01 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
what rear tire are you running?
what is your gear/tire size and converter combo?
I'm using my converter from the big block and either it needs to be loosened up or hit with a shot of nitrous
Re: Sealed Up Carb to Scoop.... [Re: gregsdart] #1644793
07/11/14 02:24 PM
07/11/14 02:24 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
"Nice work there. I don't know how effective it would be, but will offer a couple of thoughts."
A Go Pro and a dozen? tuff's of yarn strategically placed would will fill in a lot of the unknowns here, and be a pretty easy test.
Re: Sealed Up Carb to Scoop.... [Re: jcc] #1644794
07/11/14 03:17 PM
07/11/14 03:17 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I ended up blocking off the back cavity of my scoop like you, and that seemed to help with some turbulence problems that was sucking fuel out of the bleeds of my dominator, hasn't done it since,nice job on the pan, looks professional.
Re: Sealed Up Carb to Scoop.... [Re: sixpackgut] #1644795
07/11/14 03:19 PM
07/11/14 03:19 PM
STEFF Offline OP
STEFF  Offline OP
31 x 16.5 ET Street, Ford 9" with 4.57:1 gear, 8" UCC Converter. Even though the last two outings had there issues, I'm pretty sure the car will be getting a gear change to a 5:00 ratio and the converter needs the flash raised. Right now, it's hitting about 5000. Peak torque was at 5200, so I'm thinking of having it raised to 5500, but I'm kinda on the fence with the higher flash, as the car has been seeing plenty of street duty.
Re: Sealed Up Carb to Scoop.... [Re: dartman366] #1644796
07/11/14 03:21 PM
07/11/14 03:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I was thinking of doing the same w/ my cowl, wonder if it's worth the effort....
Coming soon!!!!
