Re: Sealed Up Carb to Scoop....
[Re: B3422W5]
#1644780
07/10/14 06:45 AM
07/10/14 06:45 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Nice work there. I don't know how effective it would be, but will offer a couple of thoughts. You might see some difference if the back of the scoop was unplugged. It all depends on whether the scoop is above the boundary layer coming off the front of the car, and if the air entry is smooth enough for max air flow. The back block off could be run open, holes in it, or screened, to modify the way the air moves around inside the scoop , hopefully to make it as calm as the airflow can be. I used an air cleaner base riveted to the air pan to help this. I also have a very large air filter made out of door screen to keep the bigger rocks out, and maybe keep the turbulence down around the carb inlet. One way to find out how effective your system is would be to build a system for testing that would run without the hood, but incorporate what ever you figure may improve or help air flow. air bell, taller scoop, 14x 6 inch K&N filter, (I just bought one, going on shortly!) By the way, K&N makes a pretty big rectangular 2 1/2 inch tall filter that just might fit inside your scoop. It has 180 square inches of filter area, which is supposed to flow enough to take care of about 800 hp. They have a formula on their web sight to figure it out.
[Re: 340RICK]
#1644784
07/10/14 05:49 PM
07/10/14 05:49 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Don't overlook connecting the bowl vents with a piece of tubing.
The little old lady from Pasadena is back!
[Re: Thumperdart]
#1644788
07/10/14 08:00 PM
07/10/14 08:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Can I get a play by play on the string trick? Not familiar with it
You run a string from the ft. of the hood up to the roof line and apparently would like the scoop opening above that idealy.......
You want the BOTTOM of the scoop inlet above the string
[Re: MR_P_BODY]
#1644789
07/11/14 12:22 PM
07/11/14 12:22 PM
Triple Threat
Renton Washington
Have you taken it to the track yet? Curious to hear what it runs!
[Re: Triple Threat]
#1644790
07/11/14 12:46 PM
07/11/14 12:46 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
I've been out twice, with issues that netted no real results. I'm hoping to get out tonite for some T & T, if the weather holds up.
[Re: sixpackgut]
#1644792
07/11/14 01:01 PM
07/11/14 01:01 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
what rear tire are you running?
what is your gear/tire size and converter combo?
I'm using my converter from the big block and either it needs to be loosened up or hit with a shot of nitrous
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: gregsdart]
#1644793
07/11/14 02:24 PM
07/11/14 02:24 PM
Posts: 22,697 Bitopia
jcc
Bitopia
"Nice work there. I don't know how effective it would be, but will offer a couple of thoughts."
A Go Pro and a dozen? tuff's of yarn strategically placed would will fill in a lot of the unknowns here, and be a pretty easy test.
[Re: jcc]
#1644794
07/11/14 03:17 PM
07/11/14 03:17 PM
dartman366
Mt. Vernon, Ohio
I ended up blocking off the back cavity of my scoop like you, and that seemed to help with some turbulence problems that was sucking fuel out of the bleeds of my dominator, hasn't done it since,nice job on the pan, looks professional.
[Re: sixpackgut]
#1644795
07/11/14 03:19 PM
07/11/14 03:19 PM
STEFF
31 x 16.5 ET Street, Ford 9" with 4.57:1 gear, 8" UCC Converter. Even though the last two outings had there issues, I'm pretty sure the car will be getting a gear change to a 5:00 ratio and the converter needs the flash raised. Right now, it's hitting about 5000. Peak torque was at 5200, so I'm thinking of having it raised to 5500, but I'm kinda on the fence with the higher flash, as the car has been seeing plenty of street duty.
