Criteria for running a PowerGlide #164411
12/08/08 07:04 PM
12/08/08 07:04 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
I never thought I would have to ask a question about running a Brand X tranny in my car, as my Father would beat me senseless...but it just seems to be the safest alternative to a Lenco or something like that...
The car is an all steel 72 Duster with a full cage. so I am guessing around 3400lbs but could be wrong
The engine is 500cid B1 motor with an F2 procharger, or possibly a big 106 mm turbo...HP is going to be over 1000 and I really seem to be fond of my feet as well as the cars floor-pan, windshield and even doors as shown could all get damaged in a recent thread.
Is the glide something that would even work in a car that heavy, or will a good 727 from Mr. Cope an option.
Thanks in advance
Josh
Re: Criteria for running a PowerGlide [Re: joshking440] #164412
12/08/08 08:08 PM
12/08/08 08:08 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
How do you plan to use the car?
"These go to eleven", Nigel Tufnel
Re: Criteria for running a PowerGlide [Re: blownEFI] #164413
12/08/08 08:13 PM
12/08/08 08:13 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
I will plan on street driving the car most of the time. The only drag racing will be Chrysler Classic events and Pinks, possibly a few heads up type races if it fits any rules and is fast enough, I would say maybe 8 events a year...
Re: Criteria for running a PowerGlide [Re: joshking440] #164414
12/08/08 08:17 PM
12/08/08 08:17 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Who has the best deals on Mopar Glides?
Re: Criteria for running a PowerGlide [Re: joshking440] #164415
12/08/08 08:21 PM
12/08/08 08:21 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
There's a number of builders on e-bay. just type in powerglide
Re: Criteria for running a PowerGlide [Re: rowin4] #164416
12/08/08 08:45 PM
12/08/08 08:45 PM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
I do alot of glides. and have brand new tci and coan adapters
Re: Criteria for running a PowerGlide [Re: joshking440] #164417
12/08/08 08:47 PM
12/08/08 08:47 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Either could work for you but I think you'll be happier with the 3 speed for mostly street driving. That said, you're aiming for over 1,000 hp and while a 727 will hold that the closer you get to 1,500 hp the better choice the glide becomes. If you ever plan on stepping up the power (which is easily done with boost) then you might invest in a well built glide for the long run.
Re: Criteria for running a PowerGlide [Re: blownEFI] #164418
12/08/08 08:49 PM
12/08/08 08:49 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
I was concerned with the weight of my car being an issue with a glide, but maybe its not a factor
Re: Criteria for running a PowerGlide [Re: joshking440] #164419
12/08/08 11:19 PM
12/08/08 11:19 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
My Gear Ratio is also a concern...I was instructed to run a 3.54 with a boost application, I wonder if this will hold true with the Glide and not a 727
Re: Criteria for running a PowerGlide [Re: joshking440] #164420
12/09/08 12:22 AM
12/09/08 12:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Both trans have a 1:1 high gear ratio, the 3.54 is for the
rpm at the top end and that will depend on tire size also
Re: Criteria for running a PowerGlide [Re: MR_P_BODY] #164421
12/09/08 09:16 AM
12/09/08 09:16 AM
gregsdart Offline
gregsdart  Offline
If you do the math concerning torque output to the rear tires, the converter will roughly double the motor torque by multiplication, then times the trans ratio times rear gear.
A 1400 hp motor will put out over 1000 ft lbs torque ,so lets look at it. 1000 tq x 2(converter) x trans gear 1.8 x rear 3.54 = 1000 x 2 = 2000 x 1.8 = 3600 x 3.54 = 12744 ft lbs at the axle. If you run a 33 inch tire you then convert to track thrust by 33/2 = 16.5 " radius x 12" (foot lbs) =9268 lbs of thrust at the track surface. Divide by running weight to get G force. 9268 / 3500 = 2.6 Gs. No street in the world will hold that, and it will be just right for one hairy ride down a sticky track!
Re: Criteria for running a PowerGlide [Re: gregsdart] #164422
12/09/08 11:17 AM
12/09/08 11:17 AM
Indy
Lunch is on me!
Lunch is on me!
Indy
Goodthing my tires are only 28" tall...
Re: Criteria for running a PowerGlide [Re: joshking440] #164423
12/09/08 11:28 AM
12/09/08 11:28 AM
gregsdart Offline
gregsdart  Offline
If you only plan on a 28 inch tire with that kind of power, better get lots of insurance. Car insurance, long term disability, life, to name those that come to mind. My measily 900 hp with 33.6 x 15 slicks 3000 lb car has spun the tires at 125 mph in high gear on a slick track. I can't imagine trying to hurd that kind of animal down the track.
Re: Criteria for running a PowerGlide [Re: joshking440] #164424
12/09/08 12:14 PM
12/09/08 12:14 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
Powerglide would be the best for what you are putting together. My car is 3450 and I run a powerglide. Its a nitrous motor and I'm running on a 295 M/T drag radial. The ATI Supercase is probably the best bet for switching to a p/g in a Mopar.
LBSR
Post deleted by Defbob [Re: gregsdart] #164425
12/09/08 12:30 PM
12/09/08 12:30 PM
Re: Criteria for running a PowerGlide #164426
12/09/08 01:15 PM
12/09/08 01:15 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Glide, Caddilac lock-up converter, big front drum, and an Ultra-Bell should do you just fine. You have plenty enough horsepower and torque to overcome the "weight" issue, and back in the early '60's there were lot's of GM's with glides in them.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Criteria for running a PowerGlide [Re: Slingshot383] #164427
12/09/08 03:53 PM
12/09/08 03:53 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
How do these Radial Tire Guys going 7's do it. Those cars make a truck load more power...
Re: Criteria for running a PowerGlide [Re: joshking440] #164428
12/09/08 03:58 PM
12/09/08 03:58 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Do I have any takers on "Pilot" do make my shake down passes for me....
Re: Criteria for running a PowerGlide [Re: joshking440] #164429
12/09/08 10:00 PM
12/09/08 10:00 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
No Takers?????
Post deleted by Defbob [Re: joshking440] #164430
12/09/08 10:05 PM
12/09/08 10:05 PM
