Wiper Motor Parts Compatibility
#1643930
07/08/14 03:43 AM
07/08/14 03:43 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I picked up a used wiper motor but it doesn't mate up with my wiper actuator arm. The groove in the arm is way smaller than the arm that came with the wiper motor as you can see. My B body arm Arm that came with the motor Correct arm on top. I would try to use the arm that came with it, but the plastic cam that attaches to the long arms doesn't fit on the spud as you can see. They are very different. I've got the body of this unit restored. Can I swap out the big drive gear inside the housing so that my arm will fit? Does anyone know what model car this wiper mechanism goes to?
I’m listening.
Re: Wiper Motor Parts Compatibility
[Re: ACR2000]
#1643932
07/08/14 08:57 PM
07/08/14 08:57 PM
Big Bad Bee
Spokane Valley, WA
Stephan, I think you are correct. I did a bit of digging on the web and it does look like the slot on that arm is bigger on the 68 back cars. I guess I'm off to dig for a modern motor. I have this motor all bead blasted and painted up. I'm wondering if I could just swap the gear so that the arm will fit. Any ideas on which year motors will work on a 70 coronet?
I’m listening.
[Re: BDW]
#1643934
07/08/14 10:19 PM
07/08/14 10:19 PM
Big Bad Bee
Spokane Valley, WA
Hmmmmmmm. That's a thought. I don't know well it would run if I was off center by a half a tick... I've got a bead on a 1972. Almost wonder if it would be worth it to just swap out the two transmissions or just start over for that matter.
I’m listening.
[Re: Big Bad Bee]
#1643935
07/08/14 10:30 PM
07/08/14 10:30 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
If the crank has P/N 2580934 and V Speed on it all you need is the nylon bushings for a 68 to make it work. PM me I have them.
ns1aar.com
Bruce
NS1AAR
[Re: Big Bad Bee]
#1643939
07/10/14 12:13 AM
07/10/14 12:13 AM
ns1aar
ontario calif
The crank and bushings shown on the red carpet should work with the 68 motor. The bushing you bought is for a 2sp but I've heard that it will work on a 69-70 b-body. Other than being dirty the one you have looks fine. If you could post a pic of the switch plate we might be able to see if its clocked right
NS1AAR
