Wiper Motor Parts Compatibility #1643930
07/08/14 03:43 AM
07/08/14 03:43 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I picked up a used wiper motor but it doesn't mate up with my wiper actuator arm. The groove in the arm is way smaller than the arm that came with the wiper motor as you can see.
My B body arm
Arm that came with the motor
Correct arm on top.
I would try to use the arm that came with it, but the plastic cam that attaches to the long arms doesn't fit on the spud as you can see. They are very different.
I've got the body of this unit restored. Can I swap out the big drive gear inside the housing so that my arm will fit? Does anyone know what model car this wiper mechanism goes to?
I’m listening.
Re: Wiper Motor Parts Compatibility [Re: Big Bad Bee] #1643931
07/08/14 08:33 AM
07/08/14 08:33 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Hi Bad Bee, what is the part number on the barrel of the wiper motor that you bought and also on the crank arm that came with it. From what I can see the motor on your on your picture looks to to be for a 68 or before.
Stephan
Re: Wiper Motor Parts Compatibility [Re: ACR2000] #1643932
07/08/14 08:57 PM
07/08/14 08:57 PM
Spokane Valley, WA
Spokane Valley, WA
Stephan, I think you are correct. I did a bit of digging on the web and it does look like the slot on that arm is bigger on the 68 back cars. I guess I'm off to dig for a modern motor. I have this motor all bead blasted and painted up. I'm wondering if I could just swap the gear so that the arm will fit. Any ideas on which year motors will work on a 70 coronet?
I’m listening.
Re: Wiper Motor Parts Compatibility [Re: Big Bad Bee] #1643933
07/08/14 09:19 PM
07/08/14 09:19 PM
BDW Offline
BDW  Offline
Looks like some careful Dremel work would get you there.
Re: Wiper Motor Parts Compatibility [Re: BDW] #1643934
07/08/14 10:19 PM
07/08/14 10:19 PM
Spokane Valley, WA
Spokane Valley, WA
Hmmmmmmm. That's a thought. I don't know well it would run if I was off center by a half a tick... I've got a bead on a 1972. Almost wonder if it would be worth it to just swap out the two transmissions or just start over for that matter.
I’m listening.
Re: Wiper Motor Parts Compatibility [Re: Big Bad Bee] #1643935
07/08/14 10:30 PM
07/08/14 10:30 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
If the crank has P/N 2580934 and V Speed on it all you need is the nylon bushings for a 68 to make it work. PM me I have them.
ns1aar.com
Bruce
NS1AAR
Re: Wiper Motor Parts Compatibility [Re: Big Bad Bee] #1643936
07/08/14 11:26 PM
07/08/14 11:26 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
BBad Bee, Whatever you do, make sure your wiper motor is set up (switch plate) right so that it will park correctly. It is a good idea to remove the wiper blade/arm when you will try it on.
Stephan
Re: Wiper Motor Parts Compatibility [Re: ACR2000] #1643937
07/09/14 12:59 AM
07/09/14 12:59 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Stephan
Yup what he said
NS1AAR
Re: Wiper Motor Parts Compatibility [Re: ACR2000] #1643938
07/09/14 02:48 AM
07/09/14 02:48 AM
Spokane Valley, WA
Spokane Valley, WA
Stephan
Are you saying to make sure that the plate is not 180 degrees out? How will I know?
ns1aar, the arm that goes to the wiper motor says V Speed.
I am assuming this is the bushing I need.
I ordered a bushing from R/T specialties. After going back and looking, it appears that the hole offset completely backward from the original piece. Is this for a two speed motor? look at it next to the cam that was on the wiper blade setup.
I’m listening.
Re: Wiper Motor Parts Compatibility [Re: Big Bad Bee] #1643939
07/10/14 12:13 AM
07/10/14 12:13 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
The crank and bushings shown on the red carpet should work with the 68 motor. The bushing you bought is for a 2sp but I've heard that it will work on a 69-70 b-body. Other than being dirty the one you have looks fine. If you could post a pic of the switch plate we might be able to see if its clocked right
NS1AAR
Re: Wiper Motor Parts Compatibility [Re: ns1aar] #1643940
07/10/14 01:13 AM
07/10/14 01:13 AM
Spokane Valley, WA
Spokane Valley, WA
bruce, what is the "switch plate"? The picture of the bushing on the red carpet I grabbed off eBay. I went to the local You Pick yard and picked up this. It came off a 68 imperial. it looks like the one in the picture. The metal plate it sits on is there to create a pocket covered by a rubber boot. The imperial has it's linkage external under the cowl vent. Will it work?
I’m listening.
Re: Wiper Motor Parts Compatibility [Re: Big Bad Bee] #1643941
07/10/14 08:18 AM
07/10/14 08:18 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Switch plate is the plate on top on the wiper motor.Depending on the year there is a tiny notch or mark that should be oriented in the right place depending on you car model.
Re: Wiper Motor Parts Compatibility [Re: Big Bad Bee] #1643942
07/11/14 12:11 AM
07/11/14 12:11 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I don't know never tried it. I have both types here and looking at them I would be reluctant to try it.
I have what you are looking for
NS1AAR
