Cruise control 66 polaria #1643720
07/07/14 11:21 PM
07/07/14 11:21 PM
Denison,Ia.
Cuda367 Offline OP
Cuda367  Offline OP
Denison,Ia.
Where do i go to find evrey last piece to install this on a 1966 dodge polaira.
Re: Cruise control 66 polaria [Re: Cuda367] #1643721
07/08/14 10:37 AM
07/08/14 10:37 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Off of a 1965 - 1968 Plymouth/Dodge/Chrysler that has cruise control.
Arizona Parts
Murray Park
Wildcat Wrecking
National Mo-Parts.
Re: Cruise control 66 polaria [Re: Cuda367] #1643722
07/08/14 03:54 PM
07/08/14 03:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Those early units were the Perfect Circle Auto Pilot; good luck finding one let alone one that still works.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=25122
If you're not concerned about originality, the later factory cruise control is an easy retrofit into the earlier cars.
Re: Cruise control 66 polaria [Re: John_Kunkel] #1643723
07/09/14 05:30 PM
07/09/14 05:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
John I had a complete set up from a 65 New Yorker.No one wanted it so off to the scrapyard it went.It worked perfect also.I used it all the time when I drove the car.Rocky
Chrysler Firepower
Re: Cruise control 66 polaria [Re: therocks] #1643724
07/14/14 11:52 AM
07/14/14 11:52 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
If you aren't concerned about OE for 66, could go with 70's era unit, which is way easy to install. Just need all the parts, transducer & bracket, wire harness, brake switch, turn signal stalk switch, and the lost motion link on the carburator, and the cable bracket for the carburator. Can find most of these parts off a 5th avenue and use those too . . . good luck.
Cheers
Mark
Re: Cruise control 66 polaria [Re: a12rag] #1643725
07/15/14 09:27 AM
07/15/14 09:27 AM
Commando1 Offline
Commando1  Offline
For forty years I have tried to find out the correct name of that part.
Thank you!!!
Re: Cruise control 66 polaria [Re: Commando1] #1643726
07/17/14 09:22 PM
07/17/14 09:22 PM
a12rag Offline
a12rag  Offline
Got that right out of the factory service manual !!! . . . Call me crazy, but I like having the FSM for whatever car I own !! . . .
Re: Cruise control 66 polaria [Re: a12rag] #1643727
07/18/14 10:29 AM
07/18/14 10:29 AM
Commando1 Offline
Commando1  Offline
I got every sentence ever printed.
And I missed that one...
