Re: Cruise control 66 polaria
[Re: Cuda367]
#1643721
07/08/14 10:37 AM
07/08/14 10:37 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Where do i go to find evrey last piece to install this on a 1966 dodge polaira.
Off of a 1965 - 1968 Plymouth/Dodge/Chrysler that has cruise control. Arizona Parts Murray Park Wildcat Wrecking National Mo-Parts.
[Re: John_Kunkel]
#1643723
07/09/14 05:30 PM
07/09/14 05:30 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
John I had a complete set up from a 65 New Yorker.No one wanted it so off to the scrapyard it went.It worked perfect also.I used it all the time when I drove the car.Rocky
Chrysler Firepower
[Re: therocks]
#1643724
07/14/14 11:52 AM
07/14/14 11:52 AM
Posts: 2,922 Calgary, Alberta Canada
a12rag
If you aren't concerned about OE for 66, could go with 70's era unit, which is way easy to install. Just need all the parts, transducer & bracket, wire harness, brake switch, turn signal stalk switch, and the lost motion link on the carburator, and the cable bracket for the carburator. Can find most of these parts off a 5th avenue and use those too . . . good luck.
Cheers
Mark
