Re: dodge dakota towing question
[Re: 3wracing]
#1643524
07/07/14 07:15 PM
07/07/14 07:15 PM
Challenger 1
Cincinnati, Ohio
Will a 2005 dodge dakota tow a 69 road runner on a trailer without much effort ? its a stick 6 spd 4.7 with towing package. im in pa = hills
Sure it'll do it with plenty of effort, won't be good on hills.
Let me be the first to say you need a turned up, black smoke belching cummins diesel motor to tow that.
I have pulled a BB challenger on a open trailer with our 2005 durango. It has a hemi, power was not a problem. The short wheelbase made it uncomfortable for me. But it did the job around town here. I have never driven it far and on the highway with the short WB durango. That might be dangerous?
[Re: Rhinodart]
#1643526
07/07/14 07:26 PM
07/07/14 07:26 PM
Challenger 1
Cincinnati, Ohio
I towed a 68 Dart around with my 92 Dakota V6 5-speed for years...
Wonder how much more a 69 road runner weighs than a 68 dart?
Either way it should do it, is it safe? I don't know for sure.
[Re: hp383]
#1643529
07/07/14 08:51 PM
07/07/14 08:51 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
same engine, trans, and rear end as a Ram 1500. as long as your tongue weight isn't so high that you max out the springs of the Dakota, you should be just fine.
Not a newer model like you have, but my 04 Dakota has been used to tow around club cab Dakotas on flatbed, open trailers without any problem.
caveat: flat ground, didn't set any land speed records, good weather, dry roads, etc.
**Photobucket sucks**
[Re: Telvis]
#1643532
07/07/14 11:34 PM
07/07/14 11:34 PM
Posts: 10,586 Freeport IL USA
poorboy
Freeport IL USA
So, what is the rated capacity of your 05 Dakota with a trailer towing package? Figure the Road runner at 4200, add in the 1500 trailer, is the capacity over the 5700? Trailer has good, functioning brakes, right? Is this going to be a weekly deal, or once a month for a coupe months a year?
I've been in those PA hills, the old extended cab 74 D 300 with a 440 and 66 gal of fuel (loaded, the truck weighed in at a little under 6600 lbs) pulling my tandem axle open trailer with good brakes proved, to be at its limits one day coming down one of those hills with 3 runaway truck lanes, when I was hauling a 62 Chrysler 300 F (listed as 4600 lbs). Having went through that experience, I wouldn't want to do that again, in anything less then that old D 300 or something designed to tow way more then the normal load. Pulling a trailer is 98% business as usual, 1% a huge thrill ride not to be forgotten, and, if you haul long enough, that 1% that your happy to have survived. If you ever experience either of those last 2%, you view trailer towing from a different perspective. Gene
[Re: poorboy]
#1643534
07/11/14 06:23 AM
07/11/14 06:23 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
Having owned a 1960 300F I think I would like to see one of those 62 300Fs, do you have any pictures? Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
[Re: shinnery]
#1643535
07/11/14 09:19 PM
07/11/14 09:19 PM
70Cuda383
Marysville, O-H-I-O
I think the Dakota I had was rated for 6500-7000 lbs total trailer weight, if equipped with towing package to include brake controller. Came wired from factory for a big trailer with brakes
[Re: shinnery]
#1643536
07/12/14 01:52 AM
07/12/14 01:52 AM
poorboy
Freeport IL USA
Special ordered 62 300 F? So, it was a few years ago. I know it was a 300F, wasn't sure what year. At least I knew it had canted headlights, I looked at those through my rear view mirrors for over 700 miles. Gene
[Re: dogdays]
#1643538
07/15/14 07:17 PM
07/15/14 07:17 PM
70Cuda383
Marysville, O-H-I-O
...there's always going to be those who will argue that you need a truck so big for towing, that you don't even need to use a trailer.
