dodge dakota towing question #1643523
07/07/14 07:01 PM
07/07/14 07:01 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Will a 2005 dodge dakota tow a 69 road runner on a trailer without much effort ? its a stick 6 spd 4.7 with towing package. im in pa
= hills
Re: dodge dakota towing question [Re: 3wracing] #1643524
07/07/14 07:15 PM
07/07/14 07:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
= hills
Sure it'll do it with plenty of effort, won't be good on hills.
Let me be the first to say you need a turned up, black smoke belching cummins diesel motor to tow that.
I have pulled a BB challenger on a open trailer with our 2005 durango. It has a hemi, power was not a problem. The short wheelbase made it uncomfortable for me. But it did the job around town here. I have never driven it far and on the highway with the short WB durango. That might be dangerous?
Re: dodge dakota towing question [Re: Challenger 1] #1643525
07/07/14 07:21 PM
07/07/14 07:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I towed a 68 Dart around with my 92 Dakota V6 5-speed for years...
JB Rhinehart, Realist
A-Body's RULE!
Re: dodge dakota towing question [Re: Rhinodart] #1643526
07/07/14 07:26 PM
07/07/14 07:26 PM
Cincinnati, Ohio
Cincinnati, Ohio
Wonder how much more a 69 road runner weighs than a 68 dart?
Either way it should do it, is it safe? I don't know for sure.
Re: dodge dakota towing question [Re: Challenger 1] #1643527
07/07/14 07:31 PM
07/07/14 07:31 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
road runner is about 4200
Re: dodge dakota towing question [Re: 3wracing] #1643528
07/07/14 07:43 PM
07/07/14 07:43 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
These guys seem to have good results.
http://www.dakotaforumz.com/showthread.php?t=1645
Gooseneck trailers towed by Dakota's
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: dodge dakota towing question [Re: hp383] #1643529
07/07/14 08:51 PM
07/07/14 08:51 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
same engine, trans, and rear end as a Ram 1500. as long as your tongue weight isn't so high that you max out the springs of the Dakota, you should be just fine.
Not a newer model like you have, but my 04 Dakota has been used to tow around club cab Dakotas on flatbed, open trailers without any problem.
caveat: flat ground, didn't set any land speed records, good weather, dry roads, etc.
**Photobucket sucks**
Re: dodge dakota towing question [Re: 70Cuda383] #1643530
07/07/14 08:56 PM
07/07/14 08:56 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Towed my 71 demon on a heavy u haul trailer with my 03 quad cab 4.7 auto. No problem power wise and it felt good with the longer quad cab but no hills it's flat here in IL.
Re: dodge dakota towing question [Re: ademon] #1643531
07/07/14 10:16 PM
07/07/14 10:16 PM
KY
Telvis Offline
Telvis  Offline
KY
More importantly, will it be able to stop? I had a recent issue pulling a bobcat on a crappy rental trailer that blew a tire. It pushed my 3/4 ton 4x4 quad cab Ram completely around before hitting the median. I stopped facing the opposite direction. Fortunately no one was hurt and my truck was still intact. A lot of vehicles will pull a trailer but they need to do more than just pull. They also need to be able to stop and maneuver with all the weight pushing them. I'm not sure about a Dakota. It may not be an issue pulling with it. I am sure there are folks here that know much more than me who can give you advice on that. I would recommend your trailer have really good trailer brakes.
That's King Weenie to you!
Re: dodge dakota towing question [Re: Telvis] #1643532
07/07/14 11:34 PM
07/07/14 11:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So, what is the rated capacity of your 05 Dakota with a trailer towing package?
Figure the Road runner at 4200, add in the 1500 trailer, is the capacity over the 5700? Trailer has good, functioning brakes, right? Is this going to be a weekly deal, or once a month for a coupe months a year?
I've been in those PA hills, the old extended cab 74 D 300 with a 440 and 66 gal of fuel (loaded, the truck weighed in at a little under 6600 lbs) pulling my tandem axle open trailer with good brakes proved, to be at its limits one day coming down one of those hills with 3 runaway truck lanes, when I was hauling a 62 Chrysler 300 F (listed as 4600 lbs). Having went through that experience, I wouldn't want to do that again, in anything less then that old D 300 or something designed to tow way more then the normal load. Pulling a trailer is 98% business as usual, 1% a huge thrill ride not to be forgotten, and, if you haul long enough, that 1% that your happy to have survived. If you ever experience either of those last 2%, you view trailer towing from a different perspective. Gene
Re: dodge dakota towing question [Re: 3wracing] #1643533
07/10/14 01:52 PM
07/10/14 01:52 PM
ccarson Offline
ccarson  Offline
It will do it, but it wont like it.
Check the official towing rating of that truck if your exceeding it and have an accident your insurance company will not like it either, and may not cover the loss.
Re: dodge dakota towing question [Re: poorboy] #1643534
07/11/14 06:23 AM
07/11/14 06:23 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Having owned a 1960 300F I think I would like to see one of those 62 300Fs, do you have any pictures?
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: dodge dakota towing question [Re: shinnery] #1643535
07/11/14 09:19 PM
07/11/14 09:19 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I think the Dakota I had was rated for 6500-7000 lbs total trailer weight, if equipped with towing package to include brake controller. Came wired from factory for a big trailer with brakes
Re: dodge dakota towing question [Re: shinnery] #1643536
07/12/14 01:52 AM
07/12/14 01:52 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Bryce
Special ordered 62 300 F?
So, it was a few years ago. I know it was a 300F, wasn't sure what year.
At least I knew it had canted headlights, I looked at those through my rear view mirrors for over 700 miles.
Gene
Re: dodge dakota towing question [Re: poorboy] #1643537
07/15/14 02:21 PM
07/15/14 02:21 PM
dogdays Offline
dogdays  Offline
RE: towing with the Dak
Sure it will do it, you'll just have to go slow and careful.
To Telvis: ever hear of trailer brakes?
I've towed a lot with my '64Dog half-ton and it is a handful with a trailer with a 4000 lb car on it. Trailer brakes are a must, and I end up running 70psi tire pressure to keep the rear end from swinging so much. I end up towing around 55mph. I've towed over Wolf Creek Pass and over Vail Pass, as well as flatland towing. It isn't easy but can be done, especially if you're only going to do it once.
If you're towing on a regular basis you need a 3/4 ton truck for sure.
R.
Re: dodge dakota towing question [Re: dogdays] #1643538
07/15/14 07:17 PM
07/15/14 07:17 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
...there's always going to be those who will argue that you need a truck so big for towing, that you don't even need to use a trailer.
