Steering wheel install issues--recessed shaft #1642895
07/06/14 02:56 PM
07/06/14 02:56 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I went to install the stock steering wheel on 69 GTX. The shaft that the wheel attaches too seems to have recessed into the steering column. There is not enough shaft exposed to install the wheel without the back of the wheel hitting the steering column. Why would this happen and what is the fix. When the steering wheel was removed for resto I installed the wheel from my Charger; there were no issues, there was plenty of shaft to secure the wheel and the back of the wheel did not hit the column.
Re: Steering wheel install issues--recessed shaft [Re: frank] #1642896
07/06/14 03:04 PM
07/06/14 03:04 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Frank, if it truly DID move in , you might check the shaft and see if the c clip around the shaft above the small ball bearing got dislodged.You may have to remove some turn signal switch stuff to get to it to even check.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: Steering wheel install issues--recessed shaft [Re: Sixgun] #1642897
07/06/14 03:18 PM
07/06/14 03:18 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
It absolutely moved in; there is about a 1/4 inch of spline available to use. The C clip is in place
Re: Steering wheel install issues--recessed shaft [Re: frank] #1642898
07/06/14 03:20 PM
07/06/14 03:20 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
another pic
Re: Steering wheel install issues--recessed shaft [Re: frank] #1642899
07/06/14 10:06 PM
07/06/14 10:06 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
By installing a nut a lightly tapping with a small hammer I was able to move the inner shaft to give adequate room to install the steering wheel. Something does not look right; the snap ring moved with the shaft. It seems to me that whatever supports the inner shaft should also move. Is there a way to do this? Should only the inner shaft move??
