Broken Bolt picture added
#1642328
07/05/14 08:47 PM
07/05/14 08:47 PM
Posts: 25 Wisconsin
bandman
Wisconsin
When I purchased my 73 dart I noticed the previous owner tried to take out a bolt from the alternator bracket. He heated the bolt head and mushroomed it. Of course when I tried to get it off the bolt broke. I have sprayed it down with penetrating oil for weeks and tried to get a crescent wrench on it but it hasn't worked. Any advice would be greatly appreciated.
Thanks, Bandman
PS I tried to post a picture but I can't because of the size of the picture.
Re: Broken Bolt picture added
[Re: bandman]
#1642331
07/05/14 10:43 PM
07/05/14 10:43 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Remove the bracket if you can.Then you will have a good piece to grab with a small pipe wrench or vice grips.Try heating the bolt with a propane torch then hit it with ice water.It shocks the threads.Id say it siezed in the bracket.On assembley use antisieze.Rocky
Chrysler Firepower
[Re: therocks]
#1642333
07/05/14 10:55 PM
07/05/14 10:55 PM
RapidRobert
Grab a file & file the rounded nub to a nice square so you can get a good TIGHT grip on it with some vice grips
[Re: Copper Dart]
#1642342
07/06/14 11:11 AM
07/06/14 11:11 AM
therocks
Niles , Ohio
That and Ive got some out by first trying to tighten them just a bit.For soem reason it seems if you try and tighten it just a touch most will back out after some heat and penetrant.+As for a water jacket use a bit of liquid teflon on the threads and anti sieze where it goes thru the cover.Too many gald themselves to the cover.Rocky
Chrysler Firepower
[Re: therocks]
#1642343
07/06/14 12:51 PM
07/06/14 12:51 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Just did this yesterday to an Engine that someone brought me to build. Mine had more stud sticking out but no matter what I used it wouldn't budge. I could see the coolant corrsion around the hole in the timing cover. I stripped the rest of the front of the motor apart down to a bare cover. I used a map gas tourch to heat the cover around the bolt area until I could start to carfully pry the cover off the bolt using PB blaster. I did have to apply heat again as the cover only went so far, then I tried the pipe wrench again and was able to screw the bolt out---but it was still stuck in the cover when I finally got the cover off. When I got it all off a swift hit of the hammer drove the bolt out of the cover. Took me about 40 minutes total to do all this---but the engine was on a stand.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1642344
07/06/14 05:33 PM
07/06/14 05:33 PM
therocks
Niles , Ohio
Try WD40 penetrating fluid.Ive been using it and its a lot better than PB.We used to get some stuff from Zep that was the best at the shop.IIRC Ive seen it on Ebay.Rocky
Chrysler Firepower
