Cost to repair Tranny on '06 Mega Cab? #1642166
07/05/14 08:43 AM
07/05/14 08:43 AM
Port Saint Lucie, FL
ChallengerGary Offline OP
Well, yesterday, my 2006 Ram 1500 Hemi 2WD Mega Cab decided to stop moving. Now when I put it in gear, all I get is a high pitched whining noise. Best guess what the problem is? How painful is this going to be to my wallet?
Re: Cost to repair Tranny on '06 Mega Cab? [Re: ChallengerGary] #1642167
07/05/14 12:37 PM
07/05/14 12:37 PM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
You killed it!
It sounds like you joined the Rhinodart club.
It's time for a rebuild. Kirk (in the Cowtown club) had a similar thing happen to his truck last fall. I can't recall what the exact failure was but it was something simple that let go. Once it happened the transmission ate itself.
- Stu Harmon
Re: Cost to repair Tranny on '06 Mega Cab? [Re: ChallengerGary] #1642168
07/05/14 01:17 PM
07/05/14 01:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ahhhh....the Dodge Ram "tranny death whine", I've heard that more than once in the fleet of Dud Rams I've owned....Torque converter grenades itself then floods the tranny with shrapnel....meaning complete rebuild, the last one cost me $2200 (4wd)
No more Dud Rams for me, I've had it with their tranny issues, good luck
mike
Re: Cost to repair Tranny on '06 Mega Cab? [Re: DAYCLONA] #1642169
07/05/14 01:36 PM
07/05/14 01:36 PM
kind of what i figured. not really in the budget right now but guess i don't have a choice
Re: Cost to repair Tranny on '06 Mega Cab? [Re: ChallengerGary] #1642170
07/05/14 05:27 PM
07/05/14 05:27 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Hold on before you jump to any conclusions calling the trans junk. At least you should drop the pan and see if the main sump filter has came loose from the pump causing it to suck air. Pretty common.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Cost to repair Tranny on '06 Mega Cab? [Re: 71yelladustr] #1642171
07/05/14 05:45 PM
07/05/14 05:45 PM
ok - will do
Re: Cost to repair Tranny on '06 Mega Cab? [Re: ChallengerGary] #1642172
07/06/14 02:46 PM
07/06/14 02:46 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
That is a 545RFE, they have been a great trans. Check that sump filter just like Yellowduster said. If that's ok it probably wasted the converter.
