2006 charger 3.5 blown head gasket #1641342
07/02/14 07:33 PM
07/02/14 07:33 PM
North East USA
BIGGERED Offline OP
Reasonable Title
BIGGERED  Offline OP
Reasonable Title
North East USA
A close friend of mine appears to have blown the head gasket in his 2006 charger with a 3.5 after the electric fans failed in 90 degree heat
It appears to now be hydro locked
How tolerant are these aluminum motors and heads to this situation?
Is it junk as I suspect?
Thank you
Red
Re: 2006 charger 3.5 blown head gasket [Re: BIGGERED] #1641343
07/02/14 07:59 PM
07/02/14 07:59 PM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
If it is over 100,000 miles, I'd stick a used heart in it and keep driving it. One other thing he needs to consider....if the engine got that hot, then the transmission will definitely need serviced.
Karma has no menu. You get served what you deserve.
Re: 2006 charger 3.5 blown head gasket [Re: BIGGERED] #1641344
07/02/14 07:59 PM
07/02/14 07:59 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
You won't know till ya take it apart of course. Most of the new stuff is pretty intolerant of bad overheat conditions. Warped heads,twisted heads so cams no longer fit correctly, warped block deck surfaces and egg shaped cylinders come to mind.Good luck with it.
Re: 2006 charger 3.5 blown head gasket [Re: BIGGERED] #1641345
07/02/14 09:30 PM
07/02/14 09:30 PM
IL us
I
ink Offline
ink  Offline
I
IL us
i have an 06 charger with 160,000 miles on it, the thermostat housing sprung a leak and before i knew it, it over heated to the point where i had to wait an half hour to let it cool down, before the motor would even turn over. long story short, i topped it back off and it kept over heating, i thought it was a head gasket, before a friend enlightened me to the fact that you need to bleed the cooling system,i consider my self a car guy, but bleeding a cooling system was new to me, so i'll ask, did he bleed the cooling system? My charger still runs like new. and it got hot
Re: 2006 charger 3.5 blown head gasket [Re: ink] #1641346
07/02/14 09:39 PM
07/02/14 09:39 PM
IL us
I
ink Offline
ink  Offline
I
IL us
i just realized you said it was hydrlocked??? either way its a pretty tuff motor, i was told people get 250,000 to 260,000 miles before having to put a timing belt on.
Re: 2006 charger 3.5 blown head gasket [Re: ink] #1641347
07/02/14 11:45 PM
07/02/14 11:45 PM
North East USA
BIGGERED Offline OP
Reasonable Title
BIGGERED  Offline OP
Reasonable Title
North East USA
Car only has 56k on it.
Appreciate the responses
We pulled a plug and I immediately smelled antifreeze and saw telltale signs on the plug
We will dig a little deeper
It will not even turn over starter sounds bad but we could barely turn over with a breaker bar on the crank claims no CE light until it shut off when he pulled over
Thank you
Red
Re: 2006 charger 3.5 blown head gasket [Re: BIGGERED] #1641348
08/01/14 03:53 PM
08/01/14 03:53 PM
North East USA
BIGGERED Offline OP
Reasonable Title
BIGGERED  Offline OP
Reasonable Title
North East USA
Just a follow up
My associate locked up his 55k mile 3.5
Wonder how long he drove with the ce light on
Red
