Brand X / Real Truck Interchange.. #1640649
07/01/14 12:58 PM
07/01/14 12:58 PM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
So I bought an 87 Generic Motors 3500 Dually Yesterday with a Rollback Bed on it. My plan is to strip the Chebby Drivetrain and Body, and replace it with my 68 440, and NP435 4 speed, and put either a 74-93 or 94-05 Cab and clip on it. Now my question is, has anyone ever used a GM PTO Box on a NP435 Tranny? I believe it's a Chelsea, but I haven't degreased it yet.The mounting bolt holes look the same I am just concearned with the drive gear meshing in the tranny. Thanks for your input!
Re: Brand X / Real Truck Interchange.. [Re: EV2RUNNER] #1640650
07/01/14 02:05 PM
07/01/14 02:05 PM
Guitar Jones Offline
It shouldn't be a problem but even if they are not the same I'm sure you can change the gear in the PTO. PTOs are pretty standardized.
Re: Brand X / Real Truck Interchange.. [Re: EV2RUNNER] #1640651
07/01/14 09:10 PM
07/01/14 09:10 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
Real Truck Interchange ? Sounds more like the making of a real bass turd to me .
If you want a dodge , why not just find a dodge to start with or just keep it all chevy ? Nothing wrong with that .
Unless of course you just have TOO much time and mismatched parts on your hands chevodgelet
Re: Brand X / Real Truck Interchange.. [Re: ChinooK440] #1640652
07/01/14 09:17 PM
07/01/14 09:17 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Why that's not helpful at all!
I can't even really remember a Dodge tilt bed from that era so your basic choices are chebby & terd. I assume this endeavor is about cost of those things so bring it on.
Re: Brand X / Real Truck Interchange.. [Re: redraptor] #1640653
07/01/14 09:39 PM
07/01/14 09:39 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
1974 thru 2005 is a pretty big era
Re: Brand X / Real Truck Interchange.. [Re: ChinooK440] #1640654
07/02/14 12:05 AM
07/02/14 12:05 AM
St.Clairsville Ohio
St.Clairsville Ohio
Well the reasoning behind this project is Cost for sure. I will have under $5000 in the truck by the time Im done.I would love to have a newer Dodge Cab and Chassis to put this bed on but I don't have $50,000 extra dollars laying around.The only thing GM will be the frame..The drivetrain and body will be all Mopar 68 440 and NP435..And I would keep it all Chevy if the body and motor were decent, the body is rusted out and the 350 is whipped, so I may as well swap the Mopar stuff on. And as far as a Bass Turd or whatever you call it,if you have been around trucks much, you know that 90% of drivetrain parts swap between Mopar and GM Trucks.
The steel bed and Hydraulics are really nice,and already mounted to this frame that's why Im using it. Im not afraid of a little fab work and basicly I have everything to build the truck except a 2003 or newer cab and clip if I choose to go that route. Thanks for the advice on the PTO, I will post pics this winter when I rip into things.
Re: Brand X / Real Truck Interchange.. [Re: ChinooK440] #1640655
07/02/14 12:10 AM
07/02/14 12:10 AM
St.Clairsville Ohio
St.Clairsville Ohio
If you have money to donate I will gladly accept!
Re: Brand X / Real Truck Interchange.. [Re: EV2RUNNER] #1640656
07/02/14 12:49 AM
07/02/14 12:49 AM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
I have thought about doing that... GM rollbacks 100-150 to 1 dodge around here. GM crap is real cheep. only thing I was thinking of putting a cummins/435 with a dana 80 rear. a gen 2 cab and clip..
Re: Brand X / Real Truck Interchange.. [Re: RODHALL] #1640657
07/02/14 12:58 AM
07/02/14 12:58 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Thought about it myself.
Even if you were doing a rampbed, the Chevy is so much cheaper than the few MoPars out there.
Re: Brand X / Real Truck Interchange.. [Re: RODHALL] #1640658
07/02/14 11:13 AM
07/02/14 11:13 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Shoot Chris, all you got to do is go to JerrDan over on I81 by you & they'll build it for you
Why not graft a Dodge front section of frame to the rear Chevy one with the bed
I've got a friend with one done like that
Re: Brand X / Real Truck Interchange.. [Re: BulletBob] #1640659
07/02/14 03:08 PM
07/02/14 03:08 PM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
$$$$$$$$$$$ LOL
Re: Brand X / Real Truck Interchange.. [Re: ChinooK440] #1640660
07/02/14 09:33 PM
07/02/14 09:33 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
OOOPS! Didn't see the '94-'05.
Still stand by my statement. However, I see crapload of 'em '06 & up.
Re: Brand X / Real Truck Interchange.. [Re: EV2RUNNER] #1640661
07/03/14 01:21 AM
07/03/14 01:21 AM
N
NITROUSN Offline
NITROUSN  Offline
N
90%
Re: Brand X / Real Truck Interchange.. [Re: NITROUSN] #1640662
07/03/14 11:35 PM
07/03/14 11:35 PM
St.Clairsville Ohio
St.Clairsville Ohio
90%
OK maybe not 90% But my point is that Dana and New Process Drivetrain parts are used in Both.
Re: Brand X / Real Truck Interchange.. [Re: RODHALL] #1640663
07/03/14 11:39 PM
07/03/14 11:39 PM
St.Clairsville Ohio
St.Clairsville Ohio
Id love to do a 12V Cummins with a NV4500, but I already have the 440 and 435 setup.
Re: Brand X / Real Truck Interchange.. [Re: redraptor] #1640664
07/04/14 03:04 AM
07/04/14 03:04 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My dad has an 88 dodge rollback. 360 with a 4 speed... definitely would be better with a cummins and a 5 speed, but I've taken it on 6 hour trips each way. I can't say I ever saw another one... it will be for sale soon, we just don't use it anymore. I'm content using a trailer behind my cummins ram.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
