another parts interchange question #1639145
06/27/14 03:34 PM
06/27/14 03:34 PM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
80 PU core support. What else works and lets me use my grill shell.
Re: another parts interchange question [Re: wedgeheaded] #1639146
06/27/14 05:49 PM
06/27/14 05:49 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I would think other years would work, but the headlights would be the stickler.Just have to change the mounting to your year.
1981 Dodge D150 360 auto
Re: another parts interchange question [Re: wedgeheaded] #1639147
06/27/14 06:37 PM
06/27/14 06:37 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Dual or quad lights? Definitely '80 down would be easiest and as mentioned light location.
Re: another parts interchange question [Re: redraptor] #1639148
06/27/14 07:08 PM
06/27/14 07:08 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
You can cut the earlier core support out & bolt the quad headlight brackets in
Re: another parts interchange question [Re: wedgeheaded] #1639149
06/28/14 12:19 AM
06/28/14 12:19 AM
Canada
demon Offline
demon  Offline
Canada
79-80 rad supports are unique. They have large openings and provisions for the bolted in headlight mount panels. They will accept either the quad rectangular lights or single round. The round headlights are in a different position than the 72-78 trucks. The older rad supports had the headlight mount stamped right into the suppor and was deeper set. The 79-80 round headlights stick out more and wont accept the older grille or vice versa
Also the 79-80 trucks used the new hood with a surface mounted latch so you cannot use the older hood without modifying the latch area.
The 79-80 rad support is pretty much only interchangable for those two years unless you feel like doing lots of modifying.
Re: another parts interchange question [Re: demon] #1639150
06/28/14 12:44 PM
06/28/14 12:44 PM
Friendly, WV
Friendly, WV
This is what I thought but wanted somebody to verify. Thanks
