Oil Pan For race small Block With Stock Front End #1638914
06/26/14 11:10 PM
06/26/14 11:10 PM
western PA
Sb Valiant Offline OP
western PA
I have a stock front end to work with on my 1963 Plymouth Valiant and that rules out pretty much any dry sump system. I like the 7 qt Milodon pan that's shallow and is kicked out. The Moroso 8 qt is ok and pretty much a lot of the other pans don't fit or aren't enough. I am thinking about making my own pan and I can build something good that will fit my front end. I want to have something pretty trick for a wet
sump pan. I plan on turning some where between 7400-7700 rpm round figure. Has anyone ever made or used a dragster style type pan? I like the box shaped design
and what I could do is I could cut it out and run the steering linkage right through it like on the Milodon SS pans. I know it's alot of effort for a wet sump but I have to work with my K member front end for now until I can get rid of that junk.. I would like
some opinions please. Thanks Moparts
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638915
06/26/14 11:17 PM
06/26/14 11:17 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I got a nice piece from Stef's , but it is a 7 qt. so I added an accu-sump for insurance.
Nicely baffled , has a tray and sort of a scraper.
I considered a profiled scraper , but that will be a future deal now.
Re: Oil Pan For race small Block With Stock Front End [Re: tubtar] #1638916
06/26/14 11:22 PM
06/26/14 11:22 PM
western PA
western PA
Thanks for the reply Tubtar. I've heard good thing's about there pan's. How much for one of those pans?
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638917
06/27/14 12:48 AM
06/27/14 12:48 AM
Toronto
mshred Offline
mshred  Offline
Toronto
If I was you, starting from scratch and you already have a pan in the car with the headers, mounts, etc. that you will be using, I would call up a company like Kevko and have them custom make you a pan. I called them, and they are pretty reasonable and have some nice designs.
I was going to change from my Kevko pan to a Milodon low pro pan on my 408. Then I did some research, and the sump holds only a little more then my kevko does, so I didn't think it was worth it. Time will tell if the 6 qts I am running total with my 408 will be ok for it on the track and the street.
Re: Oil Pan For race small Block With Stock Front End [Re: mshred] #1638918
06/27/14 12:51 AM
06/27/14 12:51 AM
western PA
western PA
Nothing is in the car yet and need a oil pan. I won't have to worry about headers because I'll just build them to fit the setup. Thanks for the share
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638919
06/27/14 12:57 AM
06/27/14 12:57 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Use the milodon SS pan if you can't fabricate something better. You could start with a truck pan and make one but unless you can do it yourself you could save the time and get a good working pan and move on. The dragster pan is great if you can make it fit.
Re: Oil Pan For race small Block With Stock Front End [Re: goldmember] #1638920
06/27/14 01:18 AM
06/27/14 01:18 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
The smallblock I am fixing to install has that Superstock pan. I know it's a good piece, just a little worried about ground clearance.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Oil Pan For race small Block With Stock Front End [Re: goldmember] #1638921
06/27/14 01:22 AM
06/27/14 01:22 AM
western PA
western PA
I would have to make a dragster pan because I am not sure if they even sell them for a 340? I don't think they do but I could look at the design of one and make it fit for my setup. I think that would be the best style pan you could use for a wet sump but I could very possibly be wrong.. Thanks
Re: Oil Pan For race small Block With Stock Front End [Re: B3422W5] #1638922
06/27/14 01:29 AM
06/27/14 01:29 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Yep,for a street car I'd think that may be a concern.
Re: Oil Pan For race small Block With Stock Front End [Re: B3422W5] #1638923
06/27/14 01:32 AM
06/27/14 01:32 AM
western PA
western PA
I like that pan and I think it will take some work to make it fit. Every pan I've seen Wether it was the SS Milodon or the other Milodons, Moroso, ect I haven't been impressed with the baffleing and I think I could do much better. Yes of course it will
take sometime and it's not going out and buying one and bolting it on but I have some time on my hands.
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638924
06/27/14 02:46 AM
06/27/14 02:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I build most of my SB pans... if you start with a
stock pan and cut and weld its much easier... wings
on them for volume is pretty easy then install doors
to keep the oil at the pick up... I had a dragster
pan on my R block but that was a dry sump but I
modified that pan also
Re: Oil Pan For race small Block With Stock Front End [Re: MR_P_BODY] #1638925
06/27/14 03:14 AM
06/27/14 03:14 AM
western PA
western PA
there is a lot more hardware spinning in the crankcase at thousands of revolutions per minute. The counterweights, crank pins, connecting rods, and pistons create a hurricane that whips the oil in a wet-sump engine into an aerated froth like a milkshake in a blender. As the rotating assembly spins in this dense fog of oil and air, the resulting windage losses sap horsepower.
This maelstrom in the crankcase can also blow the oil away from the oil pump pickup in a wet-sump engine. Even if the oil pressure gauge has a steady reading, the reality is that the pump isn’t supplying solid oil. It’s delivering intermittent oiling as pockets of air are pumped through the system; the gauge only registers the average pressure of this aerated mixture. Engine bearings require a hydrodynamic wedge of oil molecules to prevent destructive metal-to-metal contact. When the oil is aerated, it cannot maintain this crucial cushion between highly loaded parts.
Now consider what happens inside an engine with a dry-sump oil system. Multiple scavenge stages suck the oil out of the crankcase and deliver it to a remote tank. When this oil enters the tank tangentially, the air and oil separate, leaving a solid column of liquid to feed the pressure stage. The improvement in the quality of the oil that reaches the bearings with a dry-sump system is usually apparent when you overhaul the engine. In most instances, the bearings can be reused, while the bearings in a wet-sump motor frequently show the ill effects of intermittent oiling.
Burnouts and deceleration at the end of a run are especially hard on a wet-sump engine. It’s virtually impossible to baffle the oil pan to keep the pickup submerged under 1g deceleration. With many sportsman cars now running above 200 mph, the potential for damage in the shutdown area is real. Even if the engine isn’t running under load, it still suffers incremental damage every time the oil supply is interrupted.
Racers know that crankcase vacuum is beneficial in a competition engine, and some use an auxiliary pump to produce crankcase vacuum in a wet-sump engine. Unfortunately, this vacuum fights the oil pump; you’d really like positive pressure in the crankcase to force the oil into the pickup.
We performed an experiment with transparent oil return lines from the cylinder heads to see the effects of crankcase vacuum in a wet-sump engine. When vacuum was applied, the oil in the return lines scarcely moved; when the vacuum was removed, the oil drained quickly. If the vacuum is strong enough, it simply stalls the oil.
For this reason I recommend scavenge stages pulling only from the oil pan in a dry-sump engine. Current dry-sump pumps will generate 20 to 23 inches of vacuum, so an auxiliary vacuum pump simply isn’t needed. Several manufacturers now offer excellent pumps with twisted Roots rotors at affordable prices. These pumps are much more efficient than the spur gears that were used in the past.
A dry-sump system significantly increases horsepower by reducing parasitic windage losses. With less oil in the crankcase, ring tension can also be reduced. Rings are the chief source of friction in an engine, so reducing drag with low-tension rings is a path to “free” horsepower. In an extreme example, we saw a 70-horsepower gain in an engine with a 5.500-inch stroke after switching from wet-sump to dry-sump oiling. In a 600+ cubic-inch sportsman motor, a dry-sump system is typically 30 horsepower better than a wet-sump.
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638926
06/27/14 03:21 AM
06/27/14 03:21 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
LOL no crap.
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638927
06/27/14 03:32 AM
06/27/14 03:32 AM
western PA
western PA
I was reading up on that and I was researching about oil filters also. I had read in a Mopar Muscle magazine and seen a Amsoil motor challenge where they were building stock stroke 440's where they were aloud a .060 over bore and SR indy heads. A engine builder Jeff Dickey from J&D machine was using this big single oil filter that was atleast 2 qt capacity. His claim was that it helped keep oil away from crank but my thoughts on it is whether the filter is large or small the oil still has to go through it
first. But maybe its easier on the pump because it may reduce the pressure on the feed side? Anyway with my research I understand that a wet sump pan has it's
limitations. I plan on making the best pan I can for a wet sump. I will incorporate trap doors, all the baffleing I can get, windage tray screen, crank scrapers, ect. I am not a fan of the oil pumps that are offered for small block Mopars.. I think the setup is junk the way it is. I am leaning towards a external oil pump even though this setup isn't max effort and isn't a race block. It to me is just a much better and reliable setup. I don't want any problems. Last motor had ugly bearings from dry starts and I think it could of needed alittle more oil in the first place for the rpms.. Thanks for the replies fellows
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638928
06/27/14 06:28 AM
06/27/14 06:28 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I got the Stef's pan with a Summit discount code when they used to fly around more frequently and I seem to recall paying around 350.00 with the pickup.
Kevco is an attractive alternative too.....I have heard a lot of good about their stuff and it is as inexpensive as I have seen.
Re: Oil Pan For race small Block With Stock Front End [Re: tubtar] #1638929
06/27/14 08:35 AM
06/27/14 08:35 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Matt has the wedge shaped Milidon oil pan on his stock suspension 1970 duster but we had to modify (4 pound hammer) his 1 7/8 headmen header tubes. I also had the Milidon but recently installed a new Canton small block pan on mine to gain more header clearance. It gave me the clearance BUT My oil pressure is now dipping down during a pass and it never did before. If was rock steady. I wasn't allowed to use my racepak at the no-box race last weekend so I added an extra quart of oil. I will hook up the racepak again this weekend and give more info after Friday and Saturdays race. we did have to slightly modify Matts k member some and he uses an engine plate.
http://www.summitracing.com/parts/ctr-15-910
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Oil Pan For race small Block With Stock Front End [Re: pittsburghracer] #1638930
06/27/14 10:59 AM
06/27/14 10:59 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Ran a rear sump moroso 360 pan with the screen removed for crank clearance. Never had any oiling issues. Turned 9k. Pushrod oiling and a good drain back system.
My w2 setup with moroso pan would push the oil up in the PS head. Engine had no valve seals and always smoked on that side on top end.
I personally think the HV pumps, I ran are not necessary. A stock massaged pump is all that's necessary if you restrick oil to the heads and have a better pan. An accusump is probably the best protrction.
Re: Oil Pan For race small Block With Stock Front End [Re: Leon441] #1638931
06/27/14 04:02 PM
06/27/14 04:02 PM
western PA
western PA
Leon441 I would imagine you have a rack and pinion with out a K member or tubular K cam in your barracuda? I think a rear sump could be made to work if you could run the steering bar through it like the SS Milodon pan.. I know alot of folks have their opinions on what the best design for a pan is. Some say a rear sump is the best. Some run a box shaped pan with the side kicked out which is on high end cars. Not sure how much of a kickout you could go to the right side with a stock front end?
Re: Oil Pan For race small Block With Stock Front End [Re: Sb Valiant] #1638932
06/27/14 07:19 PM
06/27/14 07:19 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The w2 I referred to was witha stock front suspension.
I ran an Arrinton headed combo with a milodon center sump turning 9k with a 4" crank. Later went tubular k member and rack with the 360 rear sump moroso pan with the screen and scraper removed for clearance.
No doubt the rear sump holds more oil and lower in the pan. But,had zero issues with the center sump and stock front end.
