Re: Cal Tracs and Drag Radials
[Re: QTR MILR]
#1638851
06/27/14 12:15 AM
06/27/14 12:15 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes, you don't want to be to aggressive. The lower hole works best and you want to extend the shock slower then with a slick. I would recommend a good double adjustable shock. How much power are you trying to hook?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1638852
06/27/14 12:26 AM
06/27/14 12:26 AM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
650 hp in a 3610lb. B-body....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: QTR MILR]
#1638853
06/27/14 12:28 AM
06/27/14 12:28 AM
1967dartgt
Hilltown Pa
Stick or auto?
I would go bottom hole, 1/8 inch air gap on cal tracs, and what shocks do you run now?
[Re: 1967dartgt]
#1638854
06/27/14 01:36 AM
06/27/14 01:36 AM
QTR MILR
Ft. Wayne, IN.
Auto... 8" converter approx 5000rpm stall, 4.11 gears, 275-60-15 Hoosier drag radials. It will hook if I load the converter to 2000rpm but it doesn't hit the converter hard enough. Load it to 2500 and it spins.... 60 suffers regardless.... Best 60ft was 1.53 it runs 10:60 at 127mph.... I have Calvert single adjustables I haven't tried the bottom hole been all over with adjustments on the top....
Scott
[Re: 1967dartgt]
#1638855
06/27/14 05:09 AM
06/27/14 05:09 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
spot on
[Re: QTR MILR]
#1638857
06/27/14 10:18 AM
06/27/14 10:18 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
With my Satellite i run lower hole with 1 flat preload as per Calvert Racing. Rancho rear shock on full tight , qa1single adjust front shock on full loose.When i tried looser rear it spun just off the line , tighter front slowed dowm . 5000 vert , 4.1 gear and 275 radial.footbrake. Average 1.53 best of 1.50 sixty. I don't make your steam though Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1638859
06/27/14 10:43 AM
06/27/14 10:43 AM
1967dartgt
Hilltown Pa
I would try lower hole, 1/8 airgap, full tight on shocks. Front needs to be loose and have 5 inches of travel, hope you have some 90/10 in it.
[Re: 6PKRTSE]
#1638861
06/27/14 11:32 AM
06/27/14 11:32 AM
1967dartgt
Hilltown Pa
Back at that power level I was able to go 1.42 60fts on 295/65 hoosier radials. My car also liked to be flashed back then, 1200-1400 at line and it would work best that way.
[Re: 1967dartgt]
#1638862
06/27/14 11:49 AM
06/27/14 11:49 AM
QTR MILR
Ft. Wayne, IN.
I've got the 90/10's and the required 5" of travel. I've been putting more preload in it trying to hit them harder... That's why I was thinking its time to go the other way....
Scott
[Re: DemonDust]
#1638864
06/27/14 12:52 PM
06/27/14 12:52 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
So what does the 1/8" gap do vs the stock 2 flats setting that calvert suggests you start with? And how do you set the 1/8" gap? With a .125 shim then pull it out?
Yes I run .060 gap in ours.
To the other racer how much air you trying to run in the tires ?
[Re: VernMotor]
#1638865
06/27/14 01:13 PM
06/27/14 01:13 PM
QTR MILR
Ft. Wayne, IN.
I'm running 18 psi. currently....
Scott
[Re: 1967dartgt]
#1638871
06/28/14 10:58 AM
06/28/14 10:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Not to hyjack the post, but mine are in the top hole...should I change them? Haven't run the car yet but hoping to get up in the next 2 weeks. I'm running the MT Radial Pro's. and crappy Comp Eng drag shocks. I'm just looking for 1.52-1.55's
[Re: Mr.Yuck]
#1638874
06/28/14 02:42 PM
06/28/14 02:42 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mine are in the top hole also, rear shocks set on 9 and the the bolt just touching the spring. I am think about moving to bottom hole to see if it will com down the front end when it leaves. But it hooks good now. I am running M/T 315/60 Drag radials. 1.33 60 ft.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Thumperdart]
#1638876
06/28/14 03:18 PM
06/28/14 03:18 PM
D-50
North, Alabama
Do you always race w/out a hood? Cos I`m thinking there`s a few mph w/one on............
Thumper check the thread out that I posted ( hood and scoop color with pictures)I think it is on page 3 now.I don't want to hijack this thread. Tell me what you think.
[Re: D-50]
#1638878
06/29/14 12:16 PM
06/29/14 12:16 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Bottom hole, 1/4 turn preload, rancho 9 ways on 9, 20 psi in 295-65 radials. 1.320 sixty foot on motor footbraking from a fast idle at 3800+ lbs.
