Cal Tracs and Drag Radials #1638850
06/26/14 09:27 PM
06/26/14 09:27 PM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
Is it possible to hit a drag radial too hard with Cal Tracs?? I can't get this thing to hook up.... I've adjusted the shocks and bars to make it hit harder with no luck. I'm thinking I need to adjust it so it doesn't hit as hard??
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Cal Tracs and Drag Radials [Re: QTR MILR] #1638851
06/27/14 12:15 AM
06/27/14 12:15 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes, you don't want to be to aggressive. The lower hole works best and you want to extend the shock slower then with a slick. I would recommend a good double adjustable shock. How much power are you trying to hook?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Cal Tracs and Drag Radials [Re: 1967dartgt] #1638852
06/27/14 12:26 AM
06/27/14 12:26 AM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
650 hp in a 3610lb. B-body....
Scott
Re: Cal Tracs and Drag Radials [Re: QTR MILR] #1638853
06/27/14 12:28 AM
06/27/14 12:28 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Stick or auto?
I would go bottom hole, 1/8 inch air gap on cal tracs, and what shocks do you run now?
Re: Cal Tracs and Drag Radials [Re: 1967dartgt] #1638854
06/27/14 01:36 AM
06/27/14 01:36 AM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
Auto... 8" converter approx 5000rpm stall, 4.11 gears, 275-60-15 Hoosier drag radials. It will hook if I load the converter to 2000rpm but it doesn't hit the converter hard enough. Load it to 2500 and it spins.... 60 suffers regardless.... Best 60ft was 1.53 it runs 10:60 at 127mph.... I have Calvert single adjustables I haven't tried the bottom hole been all over with adjustments on the top....
Scott
Re: Cal Tracs and Drag Radials [Re: 1967dartgt] #1638855
06/27/14 05:09 AM
06/27/14 05:09 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
spot on
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Cal Tracs and Drag Radials [Re: Ian] #1638856
06/27/14 09:28 AM
06/27/14 09:28 AM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
Thanks for the tips guys... That's what I was thinking...... I'll be resetting them today!! I'll find out what happens this weekend!!
Scott
Re: Cal Tracs and Drag Radials [Re: QTR MILR] #1638857
06/27/14 10:18 AM
06/27/14 10:18 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
With my Satellite i run lower hole with 1 flat preload as per Calvert Racing. Rancho rear shock on full tight , qa1single adjust front shock on full loose.When i tried looser rear it spun just off the line , tighter front slowed dowm .
5000 vert , 4.1 gear and 275 radial.footbrake.
Average 1.53 best of 1.50 sixty. I don't make your steam though
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Cal Tracs and Drag Radials [Re: tex013] #1638858
06/27/14 10:41 AM
06/27/14 10:41 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When you get it right I think you will 60 better. My best is a 1.50 on just SS springs running 10.70's and the Cal Tracs seem to usually do better then SS springs as thats why I think you have more 60 in it. Good luck this weekend. Ron
Re: Cal Tracs and Drag Radials [Re: tex013] #1638859
06/27/14 10:43 AM
06/27/14 10:43 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would try lower hole, 1/8 airgap, full tight on shocks. Front needs to be loose and have 5 inches of travel, hope you have some 90/10 in it.
Re: Cal Tracs and Drag Radials [Re: Ian] #1638860
06/27/14 11:23 AM
06/27/14 11:23 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
spot on
I agree. This is exactly how I have my car set up but have yet to test it out. Still piecing it together.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cal Tracs and Drag Radials [Re: 6PKRTSE] #1638861
06/27/14 11:32 AM
06/27/14 11:32 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Back at that power level I was able to go 1.42 60fts on 295/65 hoosier radials. My car also liked to be flashed back then, 1200-1400 at line and it would work best that way.
Re: Cal Tracs and Drag Radials [Re: 1967dartgt] #1638862
06/27/14 11:49 AM
06/27/14 11:49 AM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
I've got the 90/10's and the required 5" of travel. I've been putting more preload in it trying to hit them harder... That's why I was thinking its time to go the other way....
Scott
Re: Cal Tracs and Drag Radials [Re: QTR MILR] #1638863
06/27/14 12:38 PM
06/27/14 12:38 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
So what does the 1/8" gap do vs the stock 2 flats setting that calvert suggests you start with? And how do you set the 1/8" gap? With a .125 shim then pull it out?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Cal Tracs and Drag Radials [Re: DemonDust] #1638864
06/27/14 12:52 PM
06/27/14 12:52 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yes I run .060 gap in ours.
To the other racer how much air you trying to run in the tires ?
Re: Cal Tracs and Drag Radials [Re: VernMotor] #1638865
06/27/14 01:13 PM
06/27/14 01:13 PM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
I'm running 18 psi. currently....
Scott
Re: Cal Tracs and Drag Radials [Re: QTR MILR] #1638866
06/27/14 06:41 PM
06/27/14 06:41 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
we ran 21-23psi in them
Re: Cal Tracs and Drag Radials [Re: VernMotor] #1638867
06/27/14 07:06 PM
06/27/14 07:06 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Thanks for chiming in Vern, he told me to make the power and he would make it hook!!
How's yours coming along Vern???
Keith
Re: Cal Tracs and Drag Radials [Re: DemonDust] #1638868
06/28/14 12:43 AM
06/28/14 12:43 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Makes it work, I just eyeball it. It's been 1.31 now on 275/60 mickey pros.
Re: Cal Tracs and Drag Radials [Re: Dunnuck Racing] #1638869
06/28/14 12:43 AM
06/28/14 12:43 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
everything is here almost clean up. and ready to put back together. will make a big dent in it this weekend.
