Re: Cal Tracs and Drag Radials [Re: VernMotor] #1638870
06/28/14 02:51 AM
06/28/14 02:51 AM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
Thanks for all the tips guys!! Went up in pressure to 20psi and set the bars in the bottom hole with 1/8" gap. The car would dead hook from there!! 60ft still isn't as fast as I think it can be but at least I have a car that hooks to play with...
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Cal Tracs and Drag Radials [Re: 1967dartgt] #1638871
06/28/14 10:58 AM
06/28/14 10:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Yes, you don't want to be to aggressive. The lower hole works best and you want to extend the shock slower then with a slick. I would recommend a good double adjustable shock. How much power are you trying to hook?
Not to hyjack the post, but mine are in the top hole...should I change them? Haven't run the car yet but hoping to get up in the next 2 weeks. I'm running the MT Radial Pro's. and crappy Comp Eng drag shocks. I'm just looking for 1.52-1.55's
Coming soon!!!!
Re: Cal Tracs and Drag Radials [Re: VernMotor] #1638872
06/28/14 11:55 AM
06/28/14 11:55 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I've never tried 23 PSI. I usually run 17-18 PSI. I will try 23. Since I drive it to the strip(75 mi), it's easier to get the pressure back up from 23 for the ride home.
Re: Cal Tracs and Drag Radials [Re: babarracuda] #1638873
06/28/14 12:27 PM
06/28/14 12:27 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
325/50/15 top hole a nickel gap leave at 1800 and get a 1.44-1.46
Re: Cal Tracs and Drag Radials [Re: Mr.Yuck] #1638874
06/28/14 02:42 PM
06/28/14 02:42 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mine are in the top hole also, rear shocks set on 9 and the the bolt just touching the spring. I am think about moving to bottom hole to see if it will com down the front end when it leaves. But it hooks good now. I am running M/T 315/60 Drag radials. 1.33 60 ft.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Cal Tracs and Drag Radials [Re: D-50] #1638875
06/28/14 03:10 PM
06/28/14 03:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do you always race w/out a hood? Cos I`m thinking there`s a few mph w/one on............
Re: Cal Tracs and Drag Radials [Re: Thumperdart] #1638876
06/28/14 03:18 PM
06/28/14 03:18 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Thumper check the thread out that I posted ( hood and scoop color with pictures)I think it is on page 3 now.I don't want to hijack this thread. Tell me what you think.
Re: Cal Tracs and Drag Radials [Re: D-50] #1638877
06/28/14 04:38 PM
06/28/14 04:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Forgot............ I would think that would help cos I slowed in the 1/8th w/out mine.............
Re: Cal Tracs and Drag Radials [Re: D-50] #1638878
06/29/14 12:16 PM
06/29/14 12:16 PM
an8sec70cuda Offline
Bottom hole, 1/4 turn preload, rancho 9 ways on 9, 20 psi in 295-65 radials.
1.320 sixty foot on motor footbraking from a fast idle at 3800+ lbs.
CHIP
'06 GMC 2500HD LBZ Duramax
