Who makes a decent u-joint for a newer Ram? #1638841
06/26/14 08:56 PM
06/26/14 08:56 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
Well I finally took the time to see where the vibration was coming from in my 04 3500 4x4 Cummins Ram, and it seems the rear u-joint is junk AGAIN! I put one in early last year, so it lasted just over a year. Who the heck makes a decent u-joint?
JB Rhinehart, Realist
A-Body's RULE!
Re: Who makes a decent u-joint for a newer Ram? [Re: Rhinodart] #1638842
06/26/14 08:59 PM
06/26/14 08:59 PM
Indiana
maxie Offline
maxie  Offline
Indiana
I got the guaranteed for life ones at first from Advance Auto, replaced them every 6 months. Took those out, went to rock auto and got moog/precision super U joints and have been trouble/squeek free for over a year now.
This is on a slightly turned up 03 cummins 4x4
Re: Who makes a decent u-joint for a newer Ram? [Re: Rhinodart] #1638843
06/26/14 09:03 PM
06/26/14 09:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Careful not to over tighten it, you can deform the caps sometimes when you put it in.
Or your yoke is wore out trashing the U joint early?
Re: Who makes a decent u-joint for a newer Ram? [Re: Challenger 1] #1638844
06/26/14 09:10 PM
06/26/14 09:10 PM
Indiana
maxie Offline
maxie  Offline
Indiana
MOOG/PRECISION Part # 295A Greasable Super Strength
At Transmission; RWD
At Center Bearing; RWD
At Rear Axle; RWD
Rear Driveshaft at Support Bearing; 4WD; Crew Cab Pickup; 4 speed trans.; 97.9' bed
Rear Driveshaft at Transmission; 4WD; Crew Cab Pickup; Standard Cab Pickup; 4 speed trans.
Rear Driveshaft at Transmission; 4WD; Crew Cab Pickup; Standard Cab Pickup; 5 speed trans.
Rear Driveshaft at Rear Axle; 4WD; Crew Cab Pickup; Standard Cab Pickup; 5 speed trans.
Rear Driveshaft at Support Bearing; 4WD; Crew Cab Pickup; 5 speed trans.; 97.9' bed
Rear Driveshaft at Rear Axle; 4WD; Crew Cab Pickup; Standard Cab Pickup; 4 speed trans.
Rock Auto, I found my receipt. $19
Re: Who makes a decent u-joint for a newer Ram? [Re: Rhinodart] #1638845
06/27/14 12:55 AM
06/27/14 12:55 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Use Spicer "Snap Tite" sealed, non grease-able U-joints.
Re: Who makes a decent u-joint for a newer Ram? [Re: DoctorDiff] #1638846
06/27/14 12:57 AM
06/27/14 12:57 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Why do you advocate 'non-greaseable'???
Re: Who makes a decent u-joint for a newer Ram? [Re: RSNOMO] #1638847
06/27/14 01:10 AM
06/27/14 01:10 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The boots on grease-able U-joints fit loose and allow dirt and water contamination.
Sealed, OEM U-joints last much longer.
Re: Who makes a decent u-joint for a newer Ram? [Re: DoctorDiff] #1638848
06/27/14 04:47 AM
06/27/14 04:47 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I was told that by the guy who built the shaft for my CrewCab
Re: Who makes a decent u-joint for a newer Ram? [Re: DoctorDiff] #1638849
06/27/14 01:35 PM
06/27/14 01:35 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Currently doing this and you are very right: On my '01 Ram I have the rear joint as greasable (Moog) and I have to really be on top of it to make it last (like every 1500 miles it needs grease), otherwise they pile up in a hurry. Pretty inconvenient. The front joint I replaced with a Spicer sealed and its' been in there for well over 100,000 miles.
For what it's worth, the Mopar U-Joint looks absolutely identical to the Spicer.
Mo' Farts
Moderated by "tbagger".
