Who makes a decent u-joint for a newer Ram?
#1638841
06/26/14 08:56 PM
06/26/14 08:56 PM
Posts: 43,553 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Well I finally took the time to see where the vibration was coming from in my 04 3500 4x4 Cummins Ram, and it seems the rear u-joint is junk AGAIN! I put one in early last year, so it lasted just over a year. Who the heck makes a decent u-joint?
JB Rhinehart, Realist
A-Body's RULE!
Re: Who makes a decent u-joint for a newer Ram?
[Re: Rhinodart]
#1638842
06/26/14 08:59 PM
06/26/14 08:59 PM
Posts: 7,063 Indiana
maxie
Indiana
I got the guaranteed for life ones at first from Advance Auto, replaced them every 6 months. Took those out, went to rock auto and got moog/precision super U joints and have been trouble/squeek free for over a year now. This is on a slightly turned up 03 cummins 4x4
[Re: Challenger 1]
#1638844
06/26/14 09:10 PM
06/26/14 09:10 PM
maxie
Indiana
MOOG/PRECISION Part # 295A Greasable Super Strength At Transmission; RWD At Center Bearing; RWD At Rear Axle; RWD Rear Driveshaft at Support Bearing; 4WD; Crew Cab Pickup; 4 speed trans.; 97.9' bed Rear Driveshaft at Transmission; 4WD; Crew Cab Pickup; Standard Cab Pickup; 4 speed trans. Rear Driveshaft at Transmission; 4WD; Crew Cab Pickup; Standard Cab Pickup; 5 speed trans. Rear Driveshaft at Rear Axle; 4WD; Crew Cab Pickup; Standard Cab Pickup; 5 speed trans. Rear Driveshaft at Support Bearing; 4WD; Crew Cab Pickup; 5 speed trans.; 97.9' bed Rear Driveshaft at Rear Axle; 4WD; Crew Cab Pickup; Standard Cab Pickup; 4 speed trans.
Rock Auto, I found my receipt. $19
[Re: DoctorDiff]
#1638848
06/27/14 04:47 AM
06/27/14 04:47 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
The boots on grease-able U-joints fit loose and allow dirt and water contamination.
Sealed, OEM U-joints last much longer.
I was told that by the guy who built the shaft for my CrewCab
