E85 ruining my oil #1638778
06/26/14 06:15 PM
06/26/14 06:15 PM
Muncie
Racebuddy Offline OP
Muncie
It takes no time for the E85 to milk down my Brad Penn oil.
It looks like crap. i run evac system and thats all. there is a tremendous amount of moisture in the motor.
Talking to a few guys at the track who run E85, they are talking about "lean out valves" and running the motor 200 degrees and such. Does not sound good to me.
Is E85 really this difficult? Small Block stroker 418,W-2, roller, drag race set up.
Re: E85 ruining my oil [Re: Racebuddy] #1638779
06/26/14 06:23 PM
06/26/14 06:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you must be pig rich, I ran the same oil all season and it still looked good.
Re: E85 ruining my oil [Re: Quicktree] #1638780
06/26/14 06:32 PM
06/26/14 06:32 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I put a vacumn pump on and that cured all the water problems. The pump came off a 1987 camaro. Put a vented catch can and plumb it in. I notice just a little water vaper for the first 2 to 3 minutes then nothing. Rember to turn the pump on before you start the motor, The crank pressure will push oil out the seals and gaskets.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: E85 ruining my oil [Re: Racebuddy] #1638781
06/26/14 06:32 PM
06/26/14 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds rich but the lean out valves work... I never
had any milking in the oil once your in the range..
even without the lean out valve.. but the lean out
valve will save you fuel during the warm up
Re: E85 ruining my oil [Re: Racebuddy] #1638782
06/26/14 06:59 PM
06/26/14 06:59 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Brad penn is a no no with e85, look it up. I used joe gibbs, and recently switched to vr1 win no issues. The oil will attract moisture. If you start the car at all, let it warm up. I let mine hit 200f before I put it up to get the moisture out. No vac pump, or evac.
Re: E85 ruining my oil [Re: 1980volare] #1638783
06/26/14 07:09 PM
06/26/14 07:09 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: E85 ruining my oil [Re: 1980volare] #1638784
06/26/14 07:45 PM
06/26/14 07:45 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Where did you read that about Brad Penn?????
Re: E85 ruining my oil [Re: Racebuddy] #1638785
06/26/14 07:59 PM
06/26/14 07:59 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
When I ran Ethanol I would let the motor warm up to at least 170* for the water to evapotate. I ran a ball valve and opened it up when I started it to lean it out to get to temp quicker once warmed up I closed it. Lean out the idle on it.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: E85 ruining my oil [Re: 440W8 Duster] #1638786
06/26/14 09:46 PM
06/26/14 09:46 PM
NC
440Jim Offline
440Jim  Offline
NC
Any alcohol fuel (methanol, ethanol, E85) needs proper tuning and procedures. Some pointers:
1) Get the idle mixture lean enough, rich milks the oil
2) Stage at 160-180F water temperature
3) Heat to 190-200 F before shutting down at the end of the night and pull the breathers for a while to let things evaporate.
4) Plug fuel vents, reinstall breathers during storage between weekends.
I never had any problems with the oil with E85 or methanol and I used Brad Penn all the time since I ran a flat tappet solid lifter cam. 2008-2013.
Re: E85 ruining my oil [Re: Racebuddy] #1638787
06/27/14 01:43 AM
06/27/14 01:43 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've been racing with E85 for two years now, no milking of the oil I did dyno tune the motor(mainly the jetting) before putting it in the car, my car has a very small cooling system so it runs 180+ on the return roads at our local 1/8 mile track, ir will run over 200 F on the return roads at the 1/4 mile tracks, maybe that is a good thing It does not cool down on the return road like a friend of mine car does who races with E85 also He has a standard radiator and cooling system, mine is tiny Mine does take some time to warm up in the morning and it does cool down quickly once it's shut off
Re: E85 ruining my oil [Re: Cab_Burge] #1638788
06/27/14 02:00 AM
06/27/14 02:00 AM
Ohio
racerAL Offline
racerAL  Offline
Ohio
ive ran e85 for 3 years, no milking of the oil at all...I use Rottella 15/40...and im also like Cab I have a undersized radiator in my car...it builds heat much quicker than it did when I had a big 3 core radiator in it..i didn't like it taking so long to build heat..and instead of going leaner, I just switched to a smaller radiator...now im 170 or so at the line...and maybe 195 down the return road.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: E85 ruining my oil [Re: racerAL] #1638789
06/27/14 10:38 AM
06/27/14 10:38 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I just started running e85 this year, no issues with the oil at all (Rotella 15-40). Building enough heat in the motor can be tough since it runs so cool on e85, but just be sure to get it up to temp and the water will vaporize (no more "milk"). I don't have any issue because I have been driving my car back and forth to the track...that gives it plenty of time to get warm.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: E85 ruining my oil [Re: FlyFish] #1638790
06/27/14 12:58 PM
06/27/14 12:58 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I run Rotella 15-40 also. I have never seen anything in my oil. and I thought I had it rich at one point. so you got it way to rich. that would be very hard to get heat in it. or you got a ring seal problem. might do a leak down on it. Lots of guys run a lean out valve on them.
Re: E85 ruining my oil [Re: FlyFish] #1638791
06/27/14 01:02 PM
06/27/14 01:02 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've been running E85 for years and the oil only gets milked if the engine is not getting warmed up enough or if there is another problem (leaking head gasket).
Do you run a thermostat? I have always run a 180 degree thermostat on E85 otherwise its difficult to get up to temp. I never run the fan/water after parking the car after a pass ...let it heat soak ...unless very late round robin.
On the final pass of the day I'll leave the fan off and water pump on so the engine is 190-200 before driving into the trailer. OEM cars run 220+ and Nascar runs crazy high temps so getting the temp up to 200 is not going to hurt anything.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: E85 ruining my oil [Re: 69dart] #1638792
06/27/14 01:10 PM
06/27/14 01:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run Brad Penn and have had no issues with milking even when the motor was pig rich at first, just like methanol,, heat is your friend to prevent moisture especially in humid conditions
Re: E85 ruining my oil [Re: dartman366] #1638793
06/27/14 03:29 PM
06/27/14 03:29 PM
western PA
Sb Valiant Offline
Sb Valiant  Offline
western PA
I know this has nothing to do with the E85 much but heat is a good thing not only forr your oil but for the "Iron Heads".. I was always told to achieve good combustion the motor needs to be around 190 degress for an iron head.. Just my
I will be running E85 this year with my small block W2 motor so this thread helps me
out ! Please correct me if I am wrong about the heat to achieve good combustion. Thanks
Re: E85 ruining my oil [Re: Racebuddy] #1638794
06/27/14 08:14 PM
06/27/14 08:14 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Make sure the evac is working. If it is the header/pipe smog valve type the smog/back-fire valves do not last long. Once the disc falls off inside the valve you could be pressurizing the crankcase.
I gave up on this type of evac and just left the hoses off.
Re: E85 ruining my oil [Re: AAR-B4] #1638795
06/28/14 12:37 AM
06/28/14 12:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont run exhaust you dont even need the valve
but at low rpm is when the valve helps.. I've run the
valve 8" away from the point where the pipe attached
the collector just to keep it farther away from the heat
and its all about the angle of the end of the pipe
and where its located in the collector for the best vac
Re: E85 ruining my oil [Re: 440Jim] #1638796
06/28/14 08:49 AM
06/28/14 08:49 AM
gregsdart Offline
gregsdart  Offline
Any alcohol needs heat to work best. Don't be afraid to see the temps get up over 200+ on the return road or during a warmup. I warm mine to 210 at the start of the day to put heat into the trans and oil, and it cools to 180/190 for the starting line easily. Ethanol will cool less than methanol, but works pretty close to the same temp wise.
Re: E85 ruining my oil [Re: slippery440] #1638797
06/28/14 09:05 AM
06/28/14 09:05 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
http://www.penngrade1.com/CMSFiles/File/March%202011_E85_TECH_LETTER_BRAD_PENN.pdf
This maybe?
Dennis
