2008 Ram 1500 Hemi Quad Cab, AC is lame
#1638648
06/26/14 10:07 AM
06/26/14 10:07 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Hello, I have an 08 1500 QC 4x4 Hemi Sport truck. It has about 83,000 miles on it and has been great since I bought it last febuary. One thing I need to look into though is that the AC is pretty weak. It eventually gets really cold but only after 20-30 minutes of driving which is longer than normal for me.
Last week on my way home i noticed that the air from the passenger side vents is pretty cold, the drivers side two vents are not near as cold. I moved all the selections around a few times and thats the way it stayed.
What could be causing the differential in temps between the two sides? The truck does not have the dual zone climate control just the typical three knob climate control panel. The heater, defrost, etc all work just fine.
Thanks for any input!
[image]https://scontent-b.xx.fbcdn.net/hphotos-xpa1/v/t1.0-9/61718_2830262373683_420851860_n.jpg?oh=32a665f7cbd4a14d601a831d66f4a802&oe=5425078E[/image]
68 Barracuda Formula S 340
Re: 2008 Ram 1500 Hemi Quad Cab, AC is lame
[Re: Bad340fish]
#1638650
06/26/14 04:03 PM
06/26/14 04:03 PM
Guitar Jones
These were good about breaking the fresh air/recirculate door. I've also seen the blend doors broken and even one that had an evaporator leaking causing that same condition you have, odd but true.
[Re: 71yelladustr]
#1638652
06/28/14 02:09 PM
06/28/14 02:09 PM
Bad340fish
Tulsa OK
The airflow is great, and you can hear the recirc door change the airflow when you switch the selector around. All of the functions of the HVAC work fine. Its just when on the AC it blows equal air out both sides, but the passenger side vents are noticably cooler.
It was mentioned on here and I got several on another board agreeing that it was likely low on freon. I'll have it checked out this week. Thanks for the responses.
Clark
