Page 1 of 5 1 2 3 4 5
Anyone running 14" brakes rotors? #1638551
06/26/14 02:35 AM
06/26/14 02:35 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Curious if anyone is running 14" brake rotors and how they worked out for wheel sizing and feel.
Whos kit and price would be nice too..
I have been looking at the Bear 14" with the 6P calipers, but they are $2,400+ each end.
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638552
06/26/14 02:42 AM
06/26/14 02:42 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Oz and Feets made their own from Mercedes rotors and Calipers. I believe 72Swinger used an AndyF kit or made his own utilizing Viper calipers. From my reading, 18" wheels are a tight fit and may require the outside edge of the rotors to be turned down to bring the calipers in a little.
Re: Anyone running 14" brakes rotors? [Re: MuuMuu101] #1638553
06/26/14 07:29 AM
06/26/14 07:29 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I run an srt rotor and viper gen 3 caliper with a bracket Dr diff had at one time. It's a killer setup with a hydroboost and 11.75 rear discs.
Re: Anyone running 14" brakes rotors? [Re: BergmanAutoCraft] #1638554
06/26/14 09:33 AM
06/26/14 09:33 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I have 14" brakes off the front end of the gen 3 & 4 vipers. 4-piston brembos and 14" rotors. Brakes feel great, stops NOW and inspires confidence in your ability to stop short when needed. Pedal modulation to avoid lock-up is easy. Snd despite efforts to heat them up with repeated hard stops, I've not experienced brake fade yet.
Wheel size, I doubt you could fit 17" wheels over these, never tried myself though. 18" is probably the safe minimum diameter.
I wouldn't go bigger than 14" rotors unless I bought super expensive aluminum hubs with bolt on rotor surface area to reduce weight. These stock viper rotors weigh around 30lbs each.
**Photobucket sucks**
Re: Anyone running 14" brakes rotors? [Re: BergmanAutoCraft] #1638555
06/26/14 09:57 AM
06/26/14 09:57 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I have the same set up in the front. Srt8 rotor = 360mm = 14.17". Rotors are 28 lb each.
And I'm running viper calipers on custom Coleman 14" rotors in the rear. Overkill for the back.
Clearance on GT500 wheels is tight but good (18x9.5 +45).
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Anyone running 14" brakes rotors? [Re: Uhcoog1] #1638556
06/26/14 10:44 AM
06/26/14 10:44 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Nice setup. I'd like to know more about your mounting brackets, and which spindle you're using. Along with the hub set-up
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638557
06/26/14 10:52 AM
06/26/14 10:52 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So I notice here for almost the first time in a decade, a brake size discussion "of mine are bigger then yours" on brakes that includes more then a mere suggestion on the package weight. We have actually made progress.
To bad its a little more complicated to include MOI in casual rotor discussions since diameter is such a factor.
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638558
06/26/14 11:34 AM
06/26/14 11:34 AM
AndyF Offline
AndyF  Offline
The mounting system is designed to handle different rotor diameters. You just add a spacer to move the caliper up to go from 13 to 14 to 15 inches.
Re: Anyone running 14" brakes rotors? [Re: 70Cuda383] #1638559
06/26/14 12:38 PM
06/26/14 12:38 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
15/16" Master Cylinder, manual
rear bias adjuster
Caddy CTS-V pads (~0.3" taller than viper pads)
'Stock' Brembo pads in rear (HP1000), Raybestos ST-47 pads in front
Front:
Spindle- 73+ a body disc
Hub- aluminum, from dr diff
Bracket- steel, from dr diff
Front:
Rear:
Floater 9"
Ruff stuff specialties weld on brake brackets chopped down and re-drilled
1.5"x1.5" aluminum bar stock for adapter
Rear:
Re: Anyone running 14" brakes rotors? [Re: AndyF] #1638560
06/26/14 12:39 PM
06/26/14 12:39 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
That is fancy. I like that.
Re: Anyone running 14" brakes rotors? [Re: jcc] #1638561
06/26/14 01:36 PM
06/26/14 01:36 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
IMO, weight matters, but in a different way than you're saying.
Ideally, you want the lightest rotors that will handle the heat. For less-than-competitive racing, I like my 28 pound rotors- they're a huge heat sink and stave off brake fade.
A point of reference - Matt Robertson road races a dodge magnum, and switched from lightweight 2 piece rotors back to factory rotors. Why? Because the two piece rotors were very expensive and wouldn't hardly last a weekend. The factory SRT8 rotors last multiple weekends, cost much less, and didn't get as hot doing so.
I agree that increasing unsprung rotating mass isn't good, but it doesn't outweigh the benefits of the increased heat sink (i.e. weight) for most.
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638562
06/26/14 05:24 PM
06/26/14 05:24 PM
AndyF Offline
AndyF  Offline
If you look in the archives you'll see a couple of magazine articles that I wrote on Tim's Valiant. We put a 13 inch Baer 6P kit on his Valiant and it works fine. Tim's car is road raced and has 150+ mph capability so it is very fast for a vintage Mopar. We could've gone 14 inch or 15 inch on the rotor size but there wasn't any reason to do so. The 13 inch rotors do the job from 150 so why go bigger. A 14 inch rotor does give you a little more leverage and a little more surface area and perhaps some additional head sink. I doubt that very many guys on here have a car that is fast enough to require a 14 inch rotor but nothing wrong with putting them on a car if you have the cash and don't mind spending it.
Re: Anyone running 14" brakes rotors? [Re: Uhcoog1] #1638563
06/26/14 05:29 PM
06/26/14 05:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I suspect that brake technology has progressed in pretty big strides lately, in the area of pads/fluids. I have been around racing applications since discs (solid) were introduced. And surprisingly Nascar had to wait for the technology to progress enough before they became a user. That said, and I have said before, any un ducted brake system that can lock a tire in use, and doesn't fade, in competition should be considered over capacity in whatever way you choose to measure. Racers have for decades added ducting/blowers to be able to reduce the size of the heat sink, and all the benefits that reduced heat sink provides. I am doubtful many here are experiencing brake fade with a properly set-up brake system ( balanced correctly, correct pads for application, fresh bleed fluid). Anybody suffering severe brake fade has a problem with their brake system, or it s undersized for the application, or their driving technique might be in need of improvement. The only way to actually determine that, is to push the system to point of approaching brake fade. That should not be hard to do, if the system is balanced properly, concerning suspension, F/R, HP, etc. If that fade is difficult to achieve, ducting will provide more then enough safety margin for one's peace of mind, if it the can't, something is not in balance and you have brake system overkill, to a proven performance detriment. I have heard others say that brake ducting is difficult, well only if you haven't tried, and F1 aero is not a big concern. Anything is a lot better then nothing. I also get a kick out of the bigger brakes givening better modulation crowd, well if you are braking at 100% thresholds at over 100mph with the typical cars here, you are first 1 in 1000? and can't be gaining much insight on this forum. If you are running under 100mph and or autocross, your oversize brakes are costing you time.
FWIW at the recent optima Daytona,less then 1/3 of the cars had brake ducting, which for a competition event seemed rather strange, it was hot, it was long, and Daytona was/is likely one of the faster courses in the series. No way to find out reliability what factor brake fade played, on most of the big brake cars. remember it is 3+ miles long, serious banking, and possible to hit 160mph.
I think the last paragraph is fairly accurate, and I'm sure there will some disagreement on how to interpret my observation.
Re: Anyone running 14" brakes rotors? [Re: AndyF] #1638564
06/26/14 05:33 PM
06/26/14 05:33 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I think any of the disc brake setups will be lighter than the 11x3" drums that are on my car now.
What is the difference with the spindles?
I know I need to change the spindles, but which is better in a '69 Coronet?
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638565
06/26/14 05:49 PM
06/26/14 05:49 PM
AndyF Offline
AndyF  Offline
I use the taller (and lighter) FMJ knuckles on everything I build.
Re: Anyone running 14" brakes rotors? [Re: AndyF] #1638566
06/26/14 06:39 PM
06/26/14 06:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mine are same as Wades in the front except for color.
Mopar to the bone!!!
Re: Anyone running 14" brakes rotors? [Re: 72Swinger] #1638567
06/27/14 05:34 AM
06/27/14 05:34 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
So what about the rear brakes?
I have a stock Dana 60 with the tapered wheel bearings.
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638568
06/27/14 01:50 PM
06/27/14 01:50 PM
AndyF Offline
AndyF  Offline
Doctor Diff has what you need.
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638569
06/27/14 05:27 PM
06/27/14 05:27 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I'm running this kit on the front of my car and I like it. As far as overall weight is concerned, it was a wash between my 10.875 rotor, slider caliper setup and the baer kit. Also 13 or 14" rotors are the same price. I like the pedal feel on mine, but I might try a different master cylinder bore to lessen the overall pedal travel a little bit. At willow springs, I didn't have any issues with fade. I think I was ~110-115 at the end of the straightaway into turn one so my car isn't as fast as others on here. I'm running the 11" stock drums in the rear. I also won't claim to be a great driver as this was my first track experience - just my 2 cents
Re: Anyone running 14" brakes rotors? [Re: jcc] #1638570
06/27/14 05:55 PM
06/27/14 05:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Someone must be ignoring my posts.
I've mentioned the weight penalty on almost every thread where I've discussed my brakes.
- Stu Harmon
