Is This a 1968 or 1969 B-Body Gauge Cluster? #1638279
06/25/14 01:58 PM
06/25/14 01:58 PM
Newburgh, NY
Old_Moparz Offline OP
Newburgh, NY
I just wanted to be sure which year this type of cluster is from before I decide to install it. I have a '69 Plymouth, but if it's for a '68 I may not use it at all. I don't have a photo of my actual cluster handy, so I used the one attached. One thing I don't remember is if the lettering is on the gauges or the lens if that matters.
Can someone verify which year this is for?
Thanks.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: Old_Moparz] #1638280
06/25/14 03:36 PM
06/25/14 03:36 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
i think that's is a 68-69 gauges.. only the 10-150 gauges are 69 only. I think not 100% sure.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: kissmyaspen] #1638281
06/25/14 04:52 PM
06/25/14 04:52 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
looks just like the one in my 69 GTX.I TAKE IT BACK,dont look nuttin like the one in my 69 GTX.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: Old_Moparz] #1638282
06/26/14 02:38 AM
06/26/14 02:38 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I was not aware there was/is a difference in 68-69 gauges. It does appear to be from a GTX since it has the 0-15 lens, RR, Sat, and others had the 0-12 lens. The lettering is on the lens itself not on the actual gauges.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: kissmyaspen] #1638283
06/26/14 03:46 AM
06/26/14 03:46 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
There are four versions of the 150MPH cluster I do know that!
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: MO_PA] #1638284
06/26/14 05:01 AM
06/26/14 05:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The 1968 model year started with the GTX & Coronet R/T 150 MPH speedometer looking a little crowded. 0 to 150
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: 6bblgt] #1638285
06/26/14 05:14 AM
06/26/14 05:14 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Mid-model year '68 (December '67?) the 0 to 15 MPH speedo came into use. The date would've varied at the three plants that assembled GTXs and Coronet R/Ts: "A" - Lynch Rd., "E" - Los Angeles, & "G" - St. Louis.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: 6bblgt] #1638286
06/26/14 05:35 AM
06/26/14 05:35 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
This cluster continued to be used for the '69 model year. There is a date on the back of the assembly & also on the tach or clock (but be aware that parts have been swapped and changed in 40+ years). Some of the '69 units also have printing (for the switched mounted below the cluster) on the face of the lens, not sure if it is an early VS. late issue or a plant issue? Another item that changed at some point is the TEMPERATURE gauge - some of them have the operating range in the center of the gauge & some have the operating range shifted to the right. The '70 Coronet R/T also used this cluster.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: 6bblgt] #1638287
06/26/14 08:56 AM
06/26/14 08:56 AM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
6bblgt, Thanks. I never knew this or probably just didn't pay attention.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: markrr] #1638288
06/26/14 09:49 AM
06/26/14 09:49 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
same here!
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: Old_Moparz] #1638289
06/26/14 11:25 AM
06/26/14 11:25 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
1969 GTX
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: bonefish] #1638290
06/26/14 11:26 AM
06/26/14 11:26 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
another
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: Old_Moparz] #1638291
06/26/14 12:54 PM
06/26/14 12:54 PM
Newburgh, NY
Newburgh, NY
Thanks for all the info & the photos, it helped a lot.
I'll have to start hunting around for a few other parts & see what is involved with swapping. I'll also have to have it checked out to make sure it works & what the final total will end up costing me. What I have is a base model Satellite with the 120 MPH cluster with a dummy plate where the clock or tach goes. I did think about simply putting the tach in place of the plate, but the 150 MPH cluster would be a nice upgrade.
Thanks again.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: Old_Moparz] #1638292
06/26/14 01:23 PM
06/26/14 01:23 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
just be carefull,that things gunna really FLY with that 150 MPH speedo in there. show us some pics when you geter in there.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: bonefish] #1638293
06/26/14 02:41 PM
06/26/14 02:41 PM
Newburgh, NY
Newburgh, NY
I'm quite a ways off with getting pics of that swap. Most people do before & after photos, but all I do are before & before that photos.
Re: Is This a 1968 or 1969 B-Body Gauge Cluster? [Re: Old_Moparz] #1638294
06/26/14 04:18 PM
06/26/14 04:18 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
looks SWEET!!
