Turbo 5.7 9.47 @ 144
#1638119
06/24/14 10:20 PM
06/24/14 10:20 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
After struggling all last year just to make it down the track we ran a new best @ Mopar Day at St Thomas last week. This was with only 14 lbs of boost. The short block was built to take 20...so there is more fun to come. Will need a parachute soon! http://s1083.photobucket.com/user/swinger440/library/
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
Re: Turbo 5.7 9.47 @ 144
[Re: Dave_S]
#1638120
06/24/14 10:59 PM
06/24/14 10:59 PM
Posts: 12,392 Taxes & Virus's R-US, NY
Dragula
Congrats....I take it your wife now approves after selling the 512 to build this engine...Sounds good too...So spill the beans on the combo if you would..I envy your combo....Very nice.
[Re: mshred]
#1638123
06/25/14 10:22 PM
06/25/14 10:22 PM
Dave_S
Thanks. As you can see in the video, the car leaves really soft, so I think the rear end is safe for a while. It handled the brute torque of the 512 with the 2.45 first gear of the old combo. I change the ring and pinion every 300 passes to be safe, and there is a fresh set of 3.23's in there now. The engine is a 5.7 out of a '05 Ram. Tall fill, 6.1 crank & cam, 6.1 oil pump and intake. Wiseco pistons, K1 rods. Eagle heads with Drag Pak springs. Trend stock length pushrods. Home built headers. The injectors are Ford Motorsport 160 lb/hr. Ebay intercooler, wastegate and throttle body. MegaSquirt 3 is in charge of the fuel, spark, boost control and data-logging The turbo is from a GMC 6v91(?) Bus. Its a T6 with a 76 mm inducer...its a HEAVY MF! Has a powerglide and a torque converter that is all wrong for this combo, but will do for now.
[Re: Dave_S]
#1638126
06/26/14 11:35 AM
06/26/14 11:35 AM
Posts: 361 Canada
onig
Canada
What RPM do you bring it to? Also when you go to Cayuga, do you typically park near the entrance gate?
69 Dart
[Re: Dave_S]
#1638129
06/26/14 12:24 PM
06/26/14 12:24 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
That's awesome, congrats!
[Re: AlexP]
#1638133
06/26/14 09:11 PM
06/26/14 09:11 PM
Dave_S
I was launching it at 2500 on the two step. About 2 lbs of boost. I have made some changes to the suspension so hopefully I can crank it up some. The heads and intake were very close, just needed a bit of matching. We always pit near the gat at TMP, its not as busy and our dog likes it!
[Re: Dave_S]
#1638134
06/27/14 11:43 AM
06/27/14 11:43 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Glad to hear it's working out, Dave! Megasquirt been working as it should since you had the initial troubles last year?
Man that thing is fast...
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1638135
06/27/14 03:42 PM
06/27/14 03:42 PM
Dave_S
MegaSquirt's been flawless once I got the start-up issues solved. It just keeps on pulling in high gear!
