Re: K-Frame, does this look right?
[Re: Mr.Yuck]
#163814
12/07/08 04:23 PM
12/07/08 04:23 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Wonder if the mounts have been moved back. I'm pretty sure this car (70 Charger) was used as a race car. Just windering if the mounts have been cut and moved back. Thanks.
Just looked at the bare 70 K frame (charger) that I have here, looks identical to yours.......have any deminsions you want to confirm?
[Re: DAYCLONA]
#163815
12/07/08 04:39 PM
12/07/08 04:39 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
what would you recommned measuring?
[Re: DAYCLONA]
#163818
12/11/08 03:38 PM
12/11/08 03:38 PM
Mr.Yuck
Brookeville, Md
That's up to you?......what do you suspect is altered?......if/when you measure. use a known reference point that is fixed on the K, like a hole, or ear tab edge, something you know will be the same on any K frame,( 70 Charger that is) triangulate measurements if you have to?
I think the engine in this car was moved back at one time or another. The car looks like it was raced. The trans tunnel has been altered it has holes in the floor for cable shift and diveshaft loop and frame connectors. Given the guys lack of turthfulness about the car I wouldn't be suprised.
[Re: Mr.Yuck]
#163821
12/12/08 11:35 AM
12/12/08 11:35 AM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
drinking busch light. The drivers one just looked odd...and the welds look like my 2 year old did the work.
Sounds like factory welds then .
