K-Frame, does this look right? #163807
12/07/08 03:40 PM
12/07/08 03:40 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Wonder if the mounts have been moved back. I'm pretty sure this car (70 Charger) was used as a race car. Just windering if the mounts have been cut and moved back. Thanks.
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163808
12/07/08 03:40 PM
12/07/08 03:40 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
2....
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163809
12/07/08 03:40 PM
12/07/08 03:40 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
3...
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163810
12/07/08 03:53 PM
12/07/08 03:53 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
looks stock to me
Re: K-Frame, does this look right? [Re: 70blackfish] #163811
12/07/08 04:04 PM
12/07/08 04:04 PM
Chesapeake, Va
4aThrill Offline
4aThrill  Offline
Chesapeake, Va
ya they look stock what have you been
Re: K-Frame, does this look right? [Re: 4aThrill] #163812
12/07/08 04:16 PM
12/07/08 04:16 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
drinking busch light. The drivers one just looked odd...and the welds look like my 2 year old did the work.
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163813
12/07/08 04:21 PM
12/07/08 04:21 PM
Kirkland, Washington
Pacnorthcuda Offline
Not sure why but K frame welds are often fugly. I've seen pieces of welding wire (2 " long!) stuck to them. Whatever company made them (Chryco?) must have use the Kframes as the welding training ground for new employees
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163814
12/07/08 04:23 PM
12/07/08 04:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Just looked at the bare 70 K frame (charger) that I have here, looks identical to yours.......have any deminsions you want to confirm?
Re: K-Frame, does this look right? [Re: DAYCLONA] #163815
12/07/08 04:39 PM
12/07/08 04:39 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
what would you recommned measuring?
Re: K-Frame, does this look right? [Re: 70blackfish] #163816
12/11/08 12:37 PM
12/11/08 12:37 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
looks stock to me
71 scamp big block with 915 heads 727 trans
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163817
12/11/08 01:15 PM
12/11/08 01:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's up to you?......what do you suspect is altered?......if/when you measure. use a known reference point that is fixed on the K, like a hole, or ear tab edge, something you know will be the same on any K frame,( 70 Charger that is) triangulate measurements if you have to?
Re: K-Frame, does this look right? [Re: DAYCLONA] #163818
12/11/08 03:38 PM
12/11/08 03:38 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I think the engine in this car was moved back at one time or another. The car looks like it was raced. The trans tunnel has been altered it has holes in the floor for cable shift and diveshaft loop and frame connectors. Given the guys lack of turthfulness about the car I wouldn't be suprised.
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163819
12/11/08 03:56 PM
12/11/08 03:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Could be a 65 or earlier,hard to tell by the pictures.It was done a lot,set the motor back about 1 3/4".The fact that the floor has been modified is a good indication.
Re: K-Frame, does this look right? [Re: 62maxwgn] #163820
12/12/08 06:31 AM
12/12/08 06:31 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Wouldn't the drive shaft then also be shorter so he could check its length and compare to stock?
Re: K-Frame, does this look right? [Re: Mr.Yuck] #163821
12/12/08 11:35 AM
12/12/08 11:35 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Sounds like factory welds then .
Re: K-Frame, does this look right? [Re: CokeBottleKid] #163822
12/12/08 12:14 PM
12/12/08 12:14 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
