E body windshield install... #1637532
06/23/14 07:26 PM
06/23/14 07:26 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
What is the best method to install e body front and rear glass?
With the ribbon or some other adhesive?
Re: E body windshield install... [Re: RV2] #1637533
06/23/14 07:31 PM
06/23/14 07:31 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
There will be two sides of the fence on this one:
1. Old school, butyl tape.
2. New School, Urathane sealer and primers. My
vote is for New School!
Admiration For Multiple Carburetor Vehicles...
Re: E body windshield install... [Re: Stewpar] #1637534
06/23/14 08:38 PM
06/23/14 08:38 PM
Md
E
EK2Runner Offline
EK2Runner  Offline
E
Md
Thats correct . If you do go Old School you will need a 5/16 butyl roll for the front and rear glass . Would also recommend you back-filling the butyl with Urethane all the way around to ensure a quality seal m again using the primers for the urethane . Also if doing it yourself , carefull with the urthane , its a bi$#h to clean from unwanted areas .
Mike
It's a Mopar thing , If you have to ask you wouldn't understand
Re: E body windshield install... [Re: EK2Runner] #1637535
06/23/14 08:56 PM
06/23/14 08:56 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
And use rubber gloves.If you get the urethane on your hands and under your finger nails it's tough to get off.
Re: E body windshield install... [Re: 5carguy] #1637536
06/24/14 08:14 AM
06/24/14 08:14 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I've a couple of these installs with AMD glass recently. Since the glass is thicker than the originals, I had to use 1/4" butyl tape to get the correct height. I backfill with a product designed for this called 3m glazing and bedding compound. Urethane is too rigid for this application.
