proform 4150,1050 cfm #1637445
06/23/14 03:14 PM
06/23/14 03:14 PM
iowa
rook440 Offline OP
rook440  Offline OP
iowa
does anyone have any experiance proform 4150 ,1050 cfm carbs,look pretty good ,just wondering if they work well,Also has anyone used the TICU air filter screen and how much air filter to hood clearance did u use ,,,thanks ,,,,
Re: proform 4150,1050 cfm [Re: rook440] #1637446
06/23/14 03:25 PM
06/23/14 03:25 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I found this on the main body swap, to a 1050 Pro Form. It sounds very positive.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6805557&Main=5919238
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: proform 4150,1050 cfm [Re: Hemi Allstate] #1637447
06/23/14 03:41 PM
06/23/14 03:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The Proforms are very good for the money...We have run a couple of them. Currently I have a 950 on my Duster, and its running 9.80's....
Re: proform 4150,1050 cfm [Re: rook440] #1637448
06/25/14 06:38 PM
06/25/14 06:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have the 1050 Pro-Form body with Quick Fuel bowls and block on my car and it's a very responsive trouble free carb
Gus
64 Plymouth Savoy
Dana 60
Re: proform 4150,1050 cfm [Re: fourgearsavoy] #1637449
06/25/14 07:19 PM
06/25/14 07:19 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I just installed a ProForm 1050 mainbody on my 68` .
LOVE IT!
Gained quite a bit of upper RPM over the 950HP.
Just came in from the first drive with the vacuum conversion. I converted it TO VACUUM from Mech. to try and manage traction. It now has more power than before,gotta slow the secondaries WAY down.
Anyway,the 1050 needs LESS jet to get the same AFR that I had with the 950,so it has excellent signal
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: proform 4150,1050 cfm [Re: 6bblFLASH] #1637450
06/25/14 08:10 PM
06/25/14 08:10 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
No info on the proform but I switched to a holley 1000 hp w annular boosters.
I like it over my 950 but only have the butt dyno as reference.
Re: proform 4150,1050 cfm [Re: Joshs68] #1637451
06/26/14 01:27 PM
06/26/14 01:27 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have three of them. Two annular booster models and one down leg. The all work great on the street and pull hard. I am going to run the two 1050's on my 511" low deck with the tunnel ram. I have a spare 1050 down leg and billet base plate. If you want to do some testing we might be able to work something out.
