proform 4150,1050 cfm
#1637445
06/23/14 03:14 PM
06/23/14 03:14 PM
Posts: 266 iowa
rook440
iowa
does anyone have any experiance proform 4150 ,1050 cfm carbs,look pretty good ,just wondering if they work well,Also has anyone used the TICU air filter screen and how much air filter to hood clearance did u use ,,,thanks ,,,,
Re: proform 4150,1050 cfm
[Re: fourgearsavoy]
#1637449
06/25/14 07:19 PM
06/25/14 07:19 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
I just installed a ProForm 1050 mainbody on my 68` . LOVE IT! Gained quite a bit of upper RPM over the 950HP. Just came in from the first drive with the vacuum conversion. I converted it TO VACUUM from Mech. to try and manage traction. It now has more power than before,gotta slow the secondaries WAY down. Anyway,the 1050 needs LESS jet to get the same AFR that I had with the 950,so it has excellent signal
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
