77 Cordoba Rear End #1637062
06/22/14 05:54 PM
06/22/14 05:54 PM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
Will a 77 Cordoba rear end fit 68-70 B Body? I only need to use it for rolling porposes, 70 Charger has the springs in place but no rear end. Need to transport the Charger and need to find a rear end locally and inexpensive.
Thanks in advance.
Re: 77 Cordoba Rear End [Re: VegasCharger] #1637063
06/22/14 07:31 PM
06/22/14 07:31 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
For what you're doing, sure. My one Magnum has an earlier 8 1/4 under it.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 77 Cordoba Rear End [Re: Magnumguy] #1637064
06/22/14 09:13 PM
06/22/14 09:13 PM
Akron, Ohio
Akron, Ohio
Thanks Magnumguy
Re: 77 Cordoba Rear End [Re: VegasCharger] #1637065
06/22/14 10:10 PM
06/22/14 10:10 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
The spring perches are about 1.5" further apart on each side. So they probably won't touch the springs, but I've used some chain to attach an axle to move a car before where the axle was too wide.
Another option is a F/M/J axle (Aspen, Diplomat, 5th Ave etc.) The spring pads will be in the right spot for a B body, just that the center pin holes are much larger.
Re: 77 Cordoba Rear End [Re: 440newport] #1637066
06/23/14 12:44 AM
06/23/14 12:44 AM
Akron, Ohio
Akron, Ohio
Another option is a F/M/J axle (Aspen, Diplomat, 5th Ave etc.) The spring pads will be in the right spot for a B body, just that the center pin holes are much larger. Thanks
Up to what years say for 5th Ave. or Diplomat?
Probably going to get this at a bone yard where the Cordoba sits. But if I can get one of those cheaper Mopars the price will be lower.
Thanks again
Re: 77 Cordoba Rear End [Re: VegasCharger] #1637067
06/23/14 05:31 PM
06/23/14 05:31 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
1976-1989 are all the same dimension
1971 Challenger
Re: 77 Cordoba Rear End [Re: cudazappa] #1637068
06/23/14 10:14 PM
06/23/14 10:14 PM
dogdays Offline
dogdays  Offline
While you're getting stuff from that '86 - '89 Fifth, score the engine too. It'll have a roller cam 318 with the 302 heads. Most look very very good after 100K miles.
Transmissions are the A998 with low First gear.
R.
