'69 AVS 4615S Questions #1635965
06/20/14 08:55 AM
06/20/14 08:55 AM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
Can anyone provide me with scans of the '69 FSM pages that cover the AVS carbs? I'm fixing up a 4615S and need some info. It has a code L8 next to the carb number. Does that mean December '68 build date? When did they switch from the single left hand thread mixture screw to the dual screws used on the SA models?
Thanks!
Re: '69 AVS 4615S Questions [Re: Pynzo] #1635966
06/20/14 10:35 AM
06/20/14 10:35 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
L8 is the date code,Dec 68,the SA is a replacement,as for the mixture screws,who knows for sure.Here is a 4617 440 4spd dated H8 with both.
Re: '69 AVS 4615S Questions [Re: 62maxwgn] #1635967
06/20/14 12:06 PM
06/20/14 12:06 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct, the cross over date (switching from a single screw to duel mixture screws) is unknown. As far as I know they never came from the factory with all 3 as shown in the pic posted above, at some point someone likely added the lower two screws to that one (which doesn't hurt anything).
Re: '69 AVS 4615S Questions [Re: ScottSmith_Harms] #1635968
06/20/14 01:55 PM
06/20/14 01:55 PM
WTH , I just (now) noticed that it has three idle mix screws
Re: '69 AVS 4615S Questions [Re: Pynzo] #1635969
06/20/14 02:20 PM
06/20/14 02:20 PM
USA
rftroy Offline
rftroy  Offline
USA
Pynzo,
Go here and download the whole manual.
http://www.mymopar.com/index.php?pid=109
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: '69 AVS 4615S Questions [Re: rftroy] #1635970
06/20/14 02:38 PM
06/20/14 02:38 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
Thanks all my questions are answered!
Re: '69 AVS 4615S Questions [Re: Pynzo] #1635971
06/21/14 04:19 AM
06/21/14 04:19 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Not that it matters much but L8 is Nov '68. The letter "I" was not used to identify the month on a Carter.
