Hughes Whiplash cam testimony. #163582
12/06/08 11:09 PM
12/06/08 11:09 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Just installed, broke in, and test drove the 69 Cuda with a Hughes Whiplash cam in it. Motor is a 100% factory '70 340 motor right down to the cast iron exhaust manifolds. I was looking for a cam that not only ran better, but sounded much manlier. Kevin at Hughes Engines talked me into the Whiplash cam for the 340. The sound is somewhere between a 284 and a 292 purple cam (which is very healthy), but I'm holding between 8 and 10 inches of vacuum. With the stock cam, the car would spin about 3/4 the way through 1st gear with my peg leg 3:23s (about to be replaced), but now it will spin far into 2nd gear. The low end is amazing compared to before, but it pulls really hard to at least 5500. I don't have timeslips yet, but I can tell that it has the stock 340 cam beat all through the RPM range, and has a radical idle that turns heads. I hadn't heard much about the Whiplash before I bought mine, but I took and chance and I couldn't be happier with it. In the next few weeks, the car will get TTI headers/exhaust and a 3:91 sure grip, so it should pick up a good deal from that too. I will post video soon with sound before and after. Just thought I would share in case anyone else was considering a Whiplash.
P.S. Link on my signature is from the old cam, not the new Whiplash.
Re: Hughes Whiplash cam testimony. [Re: OA5599] #163583
12/07/08 08:02 AM
12/07/08 08:02 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Hughes Whiplash cam testimony. [Re: MoparforLife] #163584
12/08/08 12:00 PM
12/08/08 12:00 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
TTIs headers are installed now, but my new mini starter from autozone isn't agreeing with my flywheel. I think I'll just put the old starter on it for now, I like the sound of the old starters better anyway.
Re: Hughes Whiplash cam testimony. [Re: OA5599] #163585
12/08/08 05:42 PM
12/08/08 05:42 PM
scratchnfotraction Offline
cool!!! glad to hear results on a whiplash cam
I want to get specs on a whiplash roller cam
looks like I will be calling kevin real soon also
yea a before an after sound clip,thats the ticket
Re: Hughes Whiplash cam testimony. [Re: OA5599] #163586
12/08/08 07:36 PM
12/08/08 07:36 PM
Stratford nj
cudadan Offline
cudadan  Offline
Stratford nj
good luck, hope it holds up better than there other cams
Re: Hughes Whiplash cam testimony. [Re: cudadan] #163587
12/08/08 09:24 PM
12/08/08 09:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Me too, mine is five years old and still running strong .
Re: Hughes Whiplash cam testimony. [Re: cudadan] #163588
12/08/08 09:58 PM
12/08/08 09:58 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
that might be a little uncalled for . the only problem i have with my hughes cam is keeping the front wheels down. how about a 5.91 1/8mi? it has over 116mph. yeah, bad cams
Re: Hughes Whiplash cam testimony. [Re: cudadan] #163589
12/08/08 10:04 PM
12/08/08 10:04 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If you don't know who ground the Hughes cam and who ground your current cam its hard to predict the outcome. I don't think either have purchased a cam grinder or made lobe masters as of today. For the original poster the "Whiplash" cams are a response to comps "Thumper" line,tigher LSA on small lobes for a street car that needs to sound tough.
Re: Hughes Whiplash cam testimony. [Re: goldmember] #163590
12/09/08 09:56 AM
12/09/08 09:56 AM
...poser cam...just what I want
I am gonna give one a try
just because it supposed to work with the lopo I got and the thumper needed a lot of every thing I dont have in a lopo driver
of course I am a 3/4 cam rabid parts changer
gonna run what I brung till it breaks
Re: Hughes Whiplash cam testimony. [Re: OA5599] #163591
12/09/08 11:46 AM
12/09/08 11:46 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I guess "how cool it sounds" is something we all want, but this is the Race forum, isn't it? I don't know of any tracks that award wins based on how cool a car sounds, or how far it can "spin" (although this does sound alot like how they award wins for drifting , doesn't it?).??
With that admittedly flaming response said, I too am planning a Hughes cam in my next build.
Re: Hughes Whiplash cam testimony. [Re: scratchnfotraction] #163592
12/09/08 11:53 AM
12/09/08 11:53 AM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I was skepical at first and was going to just try to pick the right performance cam. But after some thinking about it, the car sees the track maybe twice a year, other than that just cruising and car shows. But as soon as I drove it I loved it. Has a seriously nasty idle, but idles in gear just fine. Tons of low and mid range and pulls to 5500. Before this car, I had a 508 purple in a 340 and this is way more fun to drive. I ditched my cast iron manifolds in favor of TTI headers yesterday, but due to starter problems, I haven't been able to start it yet. As I said earlier, before and after vids will follow all of this in a couple of weeks.
Re: Hughes Whiplash cam testimony. [Re: OA5599] #163593
12/09/08 12:11 PM
12/09/08 12:11 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It isn't suprising that this cam works better in a street car,it's 20 plus degrees shorter than the MP cam you had.
Re: Hughes Whiplash cam testimony. [Re: OA5599] #163594
12/09/08 04:01 PM
12/09/08 04:01 PM
I am skeptical also
I dont get how it idles like a funny car and drive like a good street bruzer
is it just the high lift and short dur that duz this,of course I dont know how the # work on any of them...how is it better than the voodoo series cams
never mind,I will just try it for the funny car idle,I hardly see over 70mph and and most cruzin is 2000rpms and I like to idle a round the cruz in posing to be fast for the 3/4 cam crowd....
I will go back over to the 3/4 cam forum now
Re: Hughes Whiplash cam testimony. [Re: scratchnfotraction] #163595
12/09/08 04:32 PM
12/09/08 04:32 PM
Renton Washington
Triple Threat Offline
Renton Washington
The cam sounds "nasty" and makes the car shake or what not because it has a narrow LSA of 106. Used to be how the old race stuff was, very narrow. Now many aftermarket manufacturers are going to wider LSA's of 110 or 112.
I'd rather have people think my car is slow, and prove them wrong, than for my car to sound radical, but have little to back it up.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Hughes Whiplash cam testimony. [Re: Triple Threat] #163596
12/09/08 04:34 PM
12/09/08 04:34 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
And with the low manifold vaccum it will cause hell if you have power brakes!
Back in the swing of things at Painless again! Great to be back!
Re: Hughes Whiplash cam testimony. [Re: scratchnfotraction] #163597
12/09/08 04:39 PM
12/09/08 04:39 PM
Kirkland, Washington
Pacnorthcuda Offline
I am skeptical also
Before people started grinding cams for streetable manners AND a radical lope, the narrow LSA angle was required on a long duration cam because after all, there are only 360 degrees in a circle. In a shorter duration cam there was no reason to grind in such a narrow LSA (which means major overlap)....UNLESS, a radical idle was your goal!!!!!
Re: Hughes Whiplash cam testimony. [Re: Pacnorthcuda] #163598
12/09/08 04:46 PM
12/09/08 04:46 PM
so the lsa of 106 is what makes it choppy compared to my lsa 112 on the voodoo cam
Re: Hughes Whiplash cam testimony. [Re: scratchnfotraction] #163599
12/09/08 05:03 PM
12/09/08 05:03 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
basically, yes. a narrow LSA will also give you a slightly more peak torque, but the torque curve won't be as flat, and the powerband will drop off quicker, so while peak torque might be more, average torque over say 2000-6000 might end up slightly less than a cam identical in spec except LSA.
2017 Grand Cherokee Overland
Re: Hughes Whiplash cam testimony. [Re: StealthWedge67] #163600
12/09/08 09:07 PM
12/09/08 09:07 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
Sound is one thing I'm looking for I'm upgrading to stealth heads and an eddy 2x4 setup on my street 440 d100. I don't want to do an engine rebuild so the 106 centerline cam seems like a great idea to me.
I had a custom comp cams grind done for the last 340 I freshened. It was low comp 73 narrowed up the centerline to get some more cly pressure.
glad those whiplash cams are out there now!
At the official Mooseland dragstrip we give out a prize for distance!
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: Hughes Whiplash cam testimony. [Re: BJS racing] #163601
12/09/08 09:54 PM
12/09/08 09:54 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I am holding between 8" and 10" of vacuum with my Whiplash. How much more do you need for your brakes?
