2003 dodge ram replacement dash board #1635827
06/19/14 11:32 PM
06/19/14 11:32 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Any body bought a replacement dash? I am going to get my blend doors fixed before next winter and thought I would go ahead and replace the busted dash while it is apart and the heater core.
Anybody bought a replacement dash board? Not going to put a cover/pad on it I want it replaced. I have seen a few for sale with a lifetime warranty. In the 750 range and it comes with the vented/defrost piece
Re: 2003 dodge ram replacement dash board [Re: maxie] #1635828
06/20/14 12:25 AM
06/20/14 12:25 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Get a salvage yard dash. IMO
Re: 2003 dodge ram replacement dash board [Re: maxie] #1635829
06/20/14 01:06 AM
06/20/14 01:06 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
some guys get a used one, then glass the underside with a layer of cloth and resin.
Re: 2003 dodge ram replacement dash board [Re: Golden-Arm] #1635830
06/20/14 08:10 AM
06/20/14 08:10 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A good friend of mine replaced his. Not sure what dash he went with but it was an aftermarket and was expensive. It did turn out nice and the project wasn't all that bad to do.
68 Barracuda Formula S 340
Re: 2003 dodge ram replacement dash board [Re: Bad340fish] #1635831
06/20/14 11:04 AM
06/20/14 11:04 AM
Guitar Jones Offline
Chances of finding a good used one are going to be slim to none. I've replaced quite a few when Chrysler was participating with the repair cost but haven't done any since. The big cluster surround trim on the front tends to break apart also as soon as you touch it so be aware of that.
