Re: Steering column sqeaking
[Re: 70RR383]
#1635511
06/19/14 11:11 AM
06/19/14 11:11 AM
Challenger 1
Cincinnati, Ohio
My steering wheel every once in a while does not turn freely.It kind of get hung up and grinds??Is the an easy or temporary fix.Its beginning of summer.I really don't feel like tearing into a steering column.Thanks
Not that I know of, it sounds like the upper bearing is shot? This is the bearing you probably need.
[Re: 70RR383]
#1635512
06/19/14 01:54 PM
06/19/14 01:54 PM
Posts: 1,286 IN
GTX4spd
IN
Short term, you might try squeezing some powdered graphite inside, I've done that to cure squeaks. But grinding & binding might be more serious.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
