Re: Bouchillon AC install nightmare. HELP! [Re: Challenger 1] #1635102
06/18/14 09:47 AM
06/18/14 09:47 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Are you by any chance using a small diameter lower pulley? Could that be the problem?
Re: Bouchillon AC install nightmare. HELP! [Re: Challenger 1] #1635103
06/18/14 10:23 AM
06/18/14 10:23 AM
KY
Telvis Offline
Telvis  Offline
KY
I have the Bouchillon AC on my 340. It only uses one belt for the AC. I believe it even says so in the instructions. Only one belt will line up with the pulleys correctly. I have never had any problems at all. The Sanden compressor is much easier to spin and less strain on the motor than the old iron monster that was originally on the car. One belt does the job fine. Matter of fact, the same compress or is run on one belt in many car applications without issue.
That's King Weenie to you!
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635104
06/18/14 12:24 PM
06/18/14 12:24 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
There seems to be a spacer/bushing behind the alternator and rear plate. That spacer seems exactly the amount everything needs to go backwards, including front plate.
Any chance you have some of those plates mounted wrong (front to rear)?
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635105
06/19/14 01:23 AM
06/19/14 01:23 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
It's amazing what carefully following the directions will do for you... Oh well, the hazards of doing things late at night when your half asleep.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635106
06/19/14 09:36 AM
06/19/14 09:36 AM
west palm beach, florida
modelmakerinc Online content
modelmakerinc  Online Content
call me dumb or anal or whatever but I would not be ok with that setup, front groove not used on the compressor, rear groove not used on the alt. rear groove on the crank not used. sorry looks sloppy, wrong, bad, poorly conceived & engineered.
It may be "correct" by the instructions but wouldn't pass my standards. How much did that set-up cost from Buchellon? just my
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Bouchillon AC install nightmare. HELP! [Re: modelmakerinc] #1635107
06/19/14 09:55 AM
06/19/14 09:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Like I said above, it don't need 2 belts, one does just fine now for 10 years, same belt and I have driven my car a lot in the desert.(Vegas, Reno during August and Florida)
I can't remember what my setup cost for a SB. My BB Bouchillon setup has 2 belts.
It's really hard to find matched belts now a days anyway, so what's the point?
I surely wouldn't call you dumb or anal, just observant.
Re: Bouchillon AC install nightmare. HELP! [Re: Challenger 1] #1635108
06/19/14 10:53 AM
06/19/14 10:53 AM
BDW Offline
BDW  Offline
I'm sure it's ok, I just don't like the "visual"
Looks incomplete, that's why I went with VA.
Re: Bouchillon AC install nightmare. HELP! [Re: BDW] #1635109
06/19/14 08:51 PM
06/19/14 08:51 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
I would try to move the new compressor to align it to the OEM position and use both grooves.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Bouchillon AC install nightmare. HELP! [Re: Challenger 1] #1635110
06/19/14 08:56 PM
06/19/14 08:56 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I'd call JR at Bouchillon......
STOP right there.
That should have been the first reply.
It was in the first reply
Thanks for noticing.
To The OP Congrats on figuring out the issue.
BTW, there are plenty of clutch configurations for Sanden compressors, including single belt drives. There is no functional issues with the unused groove, they don't require as much power to run as the old Chrysler v twin monstrosity- and getting a matched set of belts is a PITA.
Re: Bouchillon AC install nightmare. HELP! [Re: Skeptic] #1635111
06/19/14 09:45 PM
06/19/14 09:45 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
doesn't goodyear sell matched sets? they used to, and the ones i used, were perfect.
