Re: best cleaner, dressing for a vinyl top
[Re: frank]
#1635059
06/17/14 11:42 PM
06/17/14 11:42 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
303 Protectant,,,use it everywhere,,,tires, interior, door rubber, rubber floor mats, under hood hoses, etc
[Re: frank]
#1635061
06/18/14 01:57 PM
06/18/14 01:57 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Never use Armor All on anything! 303 is one of the best. The key is to gently clean the top prior to applying the 303. It's easy to make burnishing marks on the top if you rub too hard in one spot.
Follow the directions on the 303 to the letter, don't use too much, use even coverage and buff off excess right away. If you apply several coats in the first few weeks, it will build up a good layer of protection and really soak into the material. Sometimes I finish it off with Griot's Vinyl Dressing, which has a bit more sheen.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: dart4forte]
#1635064
06/18/14 04:37 PM
06/18/14 04:37 PM
Posts: 1,822 Colorado
denfireguy
Colorado
How about using 303 on a dash pad? where can you buy 303?
Web page: http://www.goldeagle.com/brands/303-products
Some Walmarts, Amazon.com have it
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1635065
06/18/14 05:24 PM
06/18/14 05:24 PM
denfireguy
Colorado
Seems like most RV places have the stuff. It is on Camping World web site. I just found some at their local store.
[Re: jbc426]
#1635068
06/18/14 07:11 PM
06/18/14 07:11 PM
Posts: 4,322 St. Louis, Mo
318 Stroker
St. Louis, Mo
Sorry to disagree, but I will use nothing but Armor All on my Challenger dash pad and vinyl top, as I've done for 40 years. I've owned the car since it was 6 months old, and I still have the original uncracked dash pad. How many E-body owners can say that? My vinyl top was perfect also, but I had to replace it because some roof rust bubbled through it.
Going to go out tonight and give them another coat of Armor All...
[Re: RSNOMO]
#1635070
06/18/14 08:01 PM
06/18/14 08:01 PM
Posts: 4,145 Canada -- Posts: 4034 -Registe...
5thAve
A friend who owns a detail shop says no to Armor-All because of alcohol content...
It's not alcohol content, it's silicone based that's the problem.
[Re: 318 Stroker]
#1635072
06/18/14 10:19 PM
06/18/14 10:19 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
ive used armorall for the last 40 years on every thing for my cars and bikes,never a prob.i just recently started using Meguiars , i think i like it a little better but its not a deal breaker.
[Re: frank]
#1635073
06/18/14 11:33 PM
06/18/14 11:33 PM
Posts: 2,138 tucson az
frank
tucson az
