need Challenger wiring harness schematic
#1635028
06/17/14 11:24 PM
06/17/14 11:24 PM
Posts: 710 Harrisburg Pa. 17112
moparmikethree
I want to redo my wiring harness (engine) because it is the original wiring that was tied in for electronic ignition.. Here is what i'm working with. a lot of the wiring is cracked
70 Challenger, 360 engine, automatic, electronic ignition do in need to put in the ballast resistor? currently it is a dual post. could someone post a schematic or tell me where to look. If i ordered a new on should it be for a 72 Challenger because of the electronic ignition. is there anything on this forum
Re: need Challenger wiring harness schematic
[Re: moparmikethree]
#1635029
06/17/14 11:44 PM
06/17/14 11:44 PM
RapidRobert
IF the only difference between the '70 and the '72 harnesses is that the '72 has the extra circuits for the electronic ign & you stated you have added electronic ign then yes I would get a '72 harness. I'm assuming you are using a chrome or orange or some other ECU that is a 4 pinner? If so plug in a 2 terminal "single" ballast that has the ohms you desire to match your coil on the ballast white connector side that has the brown wire on one end, and another 2 terminal "single" ballast side by side of any ohms as it is just there to fill the harness for appearances' sake and it goes nowhere on a 4 pin ECU or a replacement parts house 5 pin which has a dummy 5th pin. Only the factory OE 5 pin ECU's have a functioning 5th pin & REQUIRE a 4 terminal "dual" ballast setup.
#1635030
06/17/14 11:44 PM
06/17/14 11:44 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Common sense is a flower that does not grow in everybody's garden
