front runners opinions #1634973
06/17/14 08:53 PM
06/17/14 08:53 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I am thinking of changing my 27.5 mickey thompson sportsman fronts on my car for the 27.5 hoosier drag fronts. When i fitted them, i was thinking i might use it on the street but now realise that was a mistake. The M/T's are 20# a side as opposed to 11# a side for the hoosiers, that's an 18# saving right at the front.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: front runners opinions [Re: deaks] #1634974
06/17/14 09:00 PM
06/17/14 09:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
Soooo whats the question?
Comparing the MT Sportsman to the Hoosier Drag front isn't apples to apples. Compare MT's ET FRONT with the DRAG front and I bet the weight is closer. Neither are Street legal however. Not sure if that matters across the pond.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: front runners opinions [Re: deaks] #1634975
06/17/14 09:01 PM
06/17/14 09:01 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You'll only get a few hundred miles out of them also
Re: front runners opinions [Re: roadhazard] #1634976
06/17/14 09:21 PM
06/17/14 09:21 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Sorry it wasn't really a question, just wanted an opinion. The car is drag only now Greg, so road mileage is not an issue.I was thinking more about losing a few pounds and if it would help weight transfer.
Mick
best 60ft 1.36
Re: front runners opinions [Re: roadhazard] #1634977
06/17/14 09:22 PM
06/17/14 09:22 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am thinking about going to M/T ET Fronts. Is that the tire you have now and changing to Hossier front. I hope to loose some weight and wondering if you are saying the hossier tires are 18 lbs lighter than the M/T ET Front tires.
Thanks...
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: front runners opinions [Re: D-50] #1634978
06/17/14 09:27 PM
06/17/14 09:27 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
No the sportsman fronts are 20# each and the hoosier fronts are 11# each. The M/T ET fronts are 12# each.
Mick
best 60ft 1.36
Re: front runners opinions [Re: deaks] #1634979
06/17/14 09:34 PM
06/17/14 09:34 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mick
Thanks for the info..........
Re: front runners opinions [Re: deaks] #1634980
06/17/14 10:21 PM
06/17/14 10:21 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes Mick that's quite a bit of weight savings and I think you should see a gain somewhere on your ticket. Maybe some of the 60' your looking for.....
I was just stating that the drag only front tires do not last but a little while when used on the street, especially if you have a spool.
Re: front runners opinions [Re: deaks] #1634981
06/17/14 10:25 PM
06/17/14 10:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mick
I went from a 165 something radial to the et fronts and iirc it was 6-8 lbs. per tire difference..............well wort it and I drive the et fronts on the street but it does track funny.............
Re: front runners opinions [Re: Thumperdart] #1634982
06/18/14 10:16 AM
06/18/14 10:16 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
They track funny b/c they're bias ply. They have a whole different feel than a radial up front.
I drove on the street for a couple years w/ ET Fronts and never had any problems. Lasted a lot longer than a couple hundred miles.
I now have the sportsman fronts b/c I drive it more on the street now than I did when it had ET Fronts. I had a 14.5:1 motor in it when I had ET Fronts no it, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: front runners opinions [Re: deaks] #1634983
06/18/14 11:27 AM
06/18/14 11:27 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I like the Moroso Drag Special. Had good luck with them and even some street use. 11# each.
http://www.jegs.com/i/Moroso/710/17100/10002/-1
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: front runners opinions [Re: an8sec70cuda] #1634984
06/18/14 02:05 PM
06/18/14 02:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I realize the bias are a bear on the street but the weight reduction is definately worth it for me..........
