fuel pressure between pump and regulator #1634855
06/17/14 03:34 PM
06/17/14 03:34 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone know if there is a standard pressure between pump and regulator? pump is in rear at cell and regulator is on front inner fender skirt using -10 line from cell to pump -8 from pump to reg. and -8 to log to carb. 6.5psi@carb. 600hp n/a application. currently have 8psi between pump and reg. measured at reg. input. also, using a davinci 1100 dom.
Re: fuel pressure between pump and regulator [Re: mopar dave] #1634856
06/17/14 03:44 PM
06/17/14 03:44 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
What pump are you running?
Most/ many fuel pumps have a preset output pressure to the regulator, which does it's job by regulating the pressure down for use at the carb.
Having said all that, 10 pounds of pressure seems low to me as an input pressure to the regulator.
Edit..... For instance the minimum pressure a magnfuel 500 puts out is like 28
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: fuel pressure between pump and regulator [Re: B3422W5] #1634857
06/17/14 03:50 PM
06/17/14 03:50 PM
Mt Morris Michigan
Mt Morris Michigan
using a SX fuel sytems pump. same as the edelbrock. 160gph. pump was preset to 12psi,but I couldn't get my carb psi down low enough, so I turned the pump down til I could get carb to 6psi. pump pressure now at 8psi.
Re: fuel pressure between pump and regulator [Re: mopar dave] #1634858
06/17/14 03:54 PM
06/17/14 03:54 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Your gonna get some haters running that dinky pump on a 600+ horse mill..lol
1.41 best 60 foot
6.60 at 103.90 1/8
Re: fuel pressure between pump and regulator [Re: B3422W5] #1634859
06/17/14 03:58 PM
06/17/14 03:58 PM
Mt Morris Michigan
Mt Morris Michigan
SX told me it will support up to 900hp.
Re: fuel pressure between pump and regulator [Re: mopar dave] #1634860
06/17/14 04:03 PM
06/17/14 04:03 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I ran a Holley black on my 422 for years and it worked fine, deadhead.
But I caved in to peer pressure and stepped up to a volumax 250 with bypass and new plumbing and didn't see squat difference.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: fuel pressure between pump and regulator [Re: mopar dave] #1634861
06/18/14 01:40 AM
06/18/14 01:40 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would get a better fuel pressure regulator so you can run the pump at its designed pressures so you don't reduce the volume to the carb. Lots of gremlins out there ready to pounce on a racer at a moments notice Fuel volume and delivery is one thing it is impossible to have to much of, just like money, traction, torque and fun
Re: fuel pressure between pump and regulator [Re: B3422W5] #1634862
06/18/14 01:58 AM
06/18/14 01:58 AM
Mt Morris Michigan
Mt Morris Michigan
dan davinici suggested I use a holley $25 pressure regulator dead headed. he's tried the more expensive ones and says the cheap holley non return works the best.
I did not follow his suggestion and bought a aeromotive return style. thought it would be easier on my pump.
