fuel pressure between pump and regulator
#1634855
06/17/14 03:34 PM
06/17/14 03:34 PM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
anyone know if there is a standard pressure between pump and regulator? pump is in rear at cell and regulator is on front inner fender skirt using -10 line from cell to pump -8 from pump to reg. and -8 to log to carb. 6.5psi@carb. 600hp n/a application. currently have 8psi between pump and reg. measured at reg. input. also, using a davinci 1100 dom.
Re: fuel pressure between pump and regulator
[Re: mopar dave]
#1634856
06/17/14 03:44 PM
06/17/14 03:44 PM
Posts: 11,706 Portage,michigan
B3422W5
Portage,michigan
What pump are you running? Most/ many fuel pumps have a preset output pressure to the regulator, which does it's job by regulating the pressure down for use at the carb. Having said all that, 10 pounds of pressure seems low to me as an input pressure to the regulator.
Edit..... For instance the minimum pressure a magnfuel 500 puts out is like 28
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#1634858
06/17/14 03:54 PM
06/17/14 03:54 PM
B3422W5
Portage,michigan
using a SX fuel sytems pump. same as the edelbrock. 160gph. pump was preset to 12psi,but I couldn't get my carb psi down low enough, so I turned the pump down til I could get carb to 6psi. pump pressure now at 8psi.
Your gonna get some haters running that dinky pump on a 600+ horse mill..lol
