EFI sys
#1634807
06/17/14 11:36 AM
06/17/14 11:36 AM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
I am tried of getting stranded by my MP elec. conv. sys. looking at putting in whole new EFI. Who has the best. anyone put them in. how well do they work. I am leaning towards the MSD sys. because it controls the timing too. whats the use in only going half way. Thanks
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
Re: EFI sys
[Re: 65cuda]
#1634810
06/17/14 10:06 PM
06/17/14 10:06 PM
Posts: 397 Colorado
Hem1orange
Colorado
I Have the MSD Atomic ready to install on my 68 Charger. http://www.atomicefi.com/Atomic_EFI_Kits.aspx I read The question board and It looked like the right setup for me. If you read into the setup you will get the return line system. Some can get by with out it but high temps and bad gas restricts using who can. If you reprogram the computer settings they claim you can run E85. Ron
Re: EFI sys
[Re: Hem1orange]
#1634811
06/17/14 11:15 PM
06/17/14 11:15 PM
Challenger 1
Cincinnati, Ohio
Ron
Me too, I just been having trouble taking my good running car apart to convert over. Plus have been pretty busy with regular life.
I wanted mine for when I take the car on vacations in higher altitudes, it's 800' here.(basically sea level imo)
Re: EFI sys
[Re: 65cuda]
#1634814
06/18/14 03:07 AM
06/18/14 03:07 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The EFI seems to be the easy part, figuring out a good fuel system is the hard part. Being cheap, I just put a sump kit on the stock fuel kit and mounted the pump near the outlet, but it looks a bit funny having the pump mounted so low. On my '69 B-Body, the fuel tank is not very deep, so I'm not sure how the in tank setup would fit, and work unless you add baffles or use the pricy Aeromotive pump with the foam baffle. I think the best solution might also be the most expensive, a custom stainless fuel tank with internal pump and baffles. A remote sump kit, like the Edelbrock one is a nice solution, but finding a place under the hood to mount it could be an issue, and it is also pretty expensive.
I used the Edelbrock XT EFI. It works good, but the control module could be better. They sell an upgrade ECU, but I read they are going to have a newer one than that pretty soon. Main reason I used the XT is hood clearance, it sits lower than my performer RPM + Holley carb setup.
