Time to add some weight
#1634635
06/16/14 08:54 PM
06/16/14 08:54 PM
Posts: 755 Rochester, PA (near Pittsburgh...
1974 474 Duster
Guess I'm going to have to add some weight to the front of my Duster. Just wants to keep getting higher on the wheel stands. Went to Goodyear front runners & lighter wheels last year. It started to come up more losing that weight. Now I added TTI step headers & she got worse. Going the hang 10# on each side. Hope that does it to get things back under control. No wheelie bars here, sorry don't like the look on my car. Car still went 1.40 60' w/pedaling it to get it back to earth. Ran 10# in the Goodyears as well. Any input would be great. Thanks, Ken Michalik
Re: Time to add some weight
[Re: 1974 474 Duster]
#1634636
06/16/14 09:32 PM
06/16/14 09:32 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
More info needed. Rear suspension. gears trans type car weight weight ratio rear tire size conv stall footbrake or trans-brake. front suspension.
[Re: pittsburghracer]
#1634637
06/16/14 10:13 PM
06/16/14 10:13 PM
1974 474 Duster
Hey John, it's a Ladder bar rear w/stock front suspension w/90-10 shocks. It has a Turbo 400 w/trans brake, Dana 60 w/4.88 gears. It weighs 3060 dry, not sure of race weight. The stall is I think 5200, leave at 3600 & let it flash from there. The rr tires are 31x14 Good Years. Like I said it always ran the tires about 2 feet in the in the air. Took some weight out of the front & this is the result. Like I said I'm going to try bolting 10# to each side on the front of the frame horns. Think that will put things back in place. Thanks, Ken
[Re: GTS340]
#1634643
06/16/14 11:42 PM
06/16/14 11:42 PM
Quicktree
Adjustable front shocks will help slow the rise down. 90/10 is really loose on extension. If you can lower the front position of the ladder bar that would help too. Maybe even consider front end travel limiters.
this also
#1634644
06/16/14 11:42 PM
06/16/14 11:42 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
#1634647
06/17/14 01:44 AM
06/17/14 01:44 AM
Posts: 698 Alberta Canada
Edge
Alberta Canada
You may want to consider a ladder bar adjustment, car looks great regardless
76 Duster
work in progress
[Re: bigtimeauto]
#1634649
06/17/14 11:14 AM
06/17/14 11:14 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If all else fails, you can drop to a 4.30 gear. It might not cost you more than a couple of hundredths ? From 4.88 to 4.30 is a 12 percent cut in torque off the line. The good thing is the converter multiplies torque longer with less gear.
[Re: gregsdart]
#1634650
06/17/14 11:30 AM
06/17/14 11:30 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
My vote is front shocks, need to slow the front end down.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: gregsdart]
#1634651
06/17/14 11:33 AM
06/17/14 11:33 AM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Frankly I can't believe I read through this and the OP( who I am sure is a nice guy and has a beautiful car) is unaware having non adjustable 90/10 shocks on a wheelstander wouldn't be the first thing to throw in a garbage can. Even a cheap CE type 3 way shock set on 70/30 or 80/20 would have an immediate impact .. Much less a higher quality shock.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
