Time to add some weight #1634635
06/16/14 08:54 PM
06/16/14 08:54 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline OP
Guess I'm going to have to add some weight to the front of my Duster. Just wants to keep getting higher on the wheel stands. Went to Goodyear front runners & lighter wheels last year. It started to come up more losing that weight. Now I added TTI step headers & she got worse. Going the hang 10# on each side. Hope that does it to get things back under control. No wheelie bars here, sorry don't like the look on my car. Car still went 1.40 60' w/pedaling it to get it back to earth. Ran 10# in the Goodyears as well. Any input would be great.
Thanks, Ken Michalik
Re: Time to add some weight [Re: 1974 474 Duster] #1634636
06/16/14 09:32 PM
06/16/14 09:32 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
More info needed.
Rear suspension.
gears
trans type
car weight
weight ratio
rear tire size
conv stall
footbrake or trans-brake.
front suspension.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Time to add some weight [Re: pittsburghracer] #1634637
06/16/14 10:13 PM
06/16/14 10:13 PM
Hey John, it's a Ladder bar rear w/stock front suspension w/90-10 shocks. It has a Turbo 400 w/trans brake, Dana 60 w/4.88 gears. It weighs 3060 dry, not sure of race weight. The stall is I think 5200, leave at 3600 & let it flash from there. The rr tires are 31x14 Good Years. Like I said it always ran the tires about 2 feet in the in the air. Took some weight out of the front & this is the result. Like I said I'm going to try bolting 10# to each side on the front of the frame horns. Think that will put things back in place.
Thanks, Ken
Re: Time to add some weight [Re: 1974 474 Duster] #1634638
06/16/14 10:28 PM
06/16/14 10:28 PM
Locomotion Offline
Locomotion  Offline
I had good results running Koni SPA1 adjustable shocks, but switched to externally adjustable QA1 Stocker Stars. I wanted to control the front end rise and be able to quickly dial it in without removing the shocks. It seemed to make a difference in wheelstand height while trying to find the initial proper setting, but I haven't needed to "open her up" in VG weather conditions yet to really test my theory.
Re: Time to add some weight [Re: 1974 474 Duster] #1634639
06/16/14 10:31 PM
06/16/14 10:31 PM
PA.
"Little"John
"Little"John
PA.
Thanks, Ken
ken did you try a ladderbar adjustment? That's a hard hit with 4.88 gear, 5200 stall, and a turbo trans. I glide would probably tame it down some as would tightning down the front end. The 90-10 shock probably isn't helping either. When I used to run a 14-31 tire on my 74 duster I ran a 4.56 gear and a 4.88 gear with a 14-32.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Time to add some weight [Re: pittsburghracer] #1634640
06/16/14 11:25 PM
06/16/14 11:25 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Adjustable front shocks will help slow the rise down. 90/10 is really loose on extension. If you can lower the front position of the ladder bar that would help too. Maybe even consider front end travel limiters.
Re: Time to add some weight [Re: 1974 474 Duster] #1634641
06/16/14 11:35 PM
06/16/14 11:35 PM
I would try raising the starting line RPM to see if that reduces the amount of the wheelstand
Re: Time to add some weight [Re: Cab_Burge] #1634642
06/16/14 11:40 PM
06/16/14 11:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
try lowering the launch rpm, I bet it helps
Re: Time to add some weight [Re: GTS340] #1634643
06/16/14 11:42 PM
06/16/14 11:42 PM
Q
Quicktree Offline
Quicktree  Offline
Q
this also
Re: Time to add some weight [Re: 1974 474 Duster] #1634644
06/16/14 11:42 PM
06/16/14 11:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Front shocks.
RIP Monte Smith
Re: Time to add some weight [Re: CompWedgeEngines] #1634645
06/17/14 12:48 AM
06/17/14 12:48 AM
gregsdart Offline
gregsdart  Offline
Front shocks.
And maybe one step stiffer springs. Can you lower the whole car a bit? I would try each of these one at a time though.
It seems a shame to have to add weight, and I suspect 20 lbs won't be near enough.
Re: Time to add some weight [Re: gregsdart] #1634646
06/17/14 01:33 AM
06/17/14 01:33 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Front shocks. Are yours adjustable, most are. 50/50 70/30 90/10. Mine are and they werent top dollar shocks either. Start there IMO
Re: Time to add some weight [Re: 1974 474 Duster] #1634647
06/17/14 01:44 AM
06/17/14 01:44 AM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
You may want to consider a ladder bar adjustment, car looks great regardless
76 Duster work in progress
Re: Time to add some weight [Re: CompWedgeEngines] #1634648
06/17/14 02:34 AM
06/17/14 02:34 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Front shocks.
need to be thrown in the trash and a set of real ones put in their place. leave the back alone!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Time to add some weight [Re: bigtimeauto] #1634649
06/17/14 11:14 AM
06/17/14 11:14 AM
gregsdart Offline
gregsdart  Offline
If all else fails, you can drop to a 4.30 gear. It might not cost you more than a couple of hundredths ? From 4.88 to 4.30 is a 12 percent cut in torque off the line. The good thing is the converter multiplies torque longer with less gear.
Re: Time to add some weight [Re: gregsdart] #1634650
06/17/14 11:30 AM
06/17/14 11:30 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My vote is front shocks, need to slow the front end down.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Time to add some weight [Re: gregsdart] #1634651
06/17/14 11:33 AM
06/17/14 11:33 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Frankly I can't believe I read through this and the OP( who I am sure is a nice guy and has a beautiful car) is unaware having non adjustable 90/10 shocks on a wheelstander wouldn't be the first thing to throw in a garbage can.
Even a cheap CE type 3 way shock set on 70/30 or 80/20 would have an immediate impact .. Much less a higher quality shock.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Time to add some weight [Re: B3422W5] #1634652
06/17/14 01:01 PM
06/17/14 01:01 PM
Sorry just for to mention that. They are Lakewood adjustable front shocks on the car. Was late when I posted last night. Thanks, Ken
Re: Time to add some weight [Re: 1974 474 Duster] #1634653
06/17/14 01:14 PM
06/17/14 01:14 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Then tighten them up.
Re: Time to add some weight [Re: 1967dartgt] #1634654
06/17/14 01:16 PM
06/17/14 01:16 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
1.41 best 60 foot
6.60 at 103.90 1/8
