Re: Any experience/info on Yukon 8 3/4 nodular iron case?
[Re: Charger453]
#1634230
06/16/14 01:11 AM
06/16/14 01:11 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I saw one at his shop yesterday and it looks way better than the stock one in every way
[Re: DoctorDiff]
#1634234
06/16/14 12:04 PM
06/16/14 12:04 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Is this a lot stronger then the stock one? I am running the 742 case now, Would I want to replace it with the 742? I have been running this one for four years. I was thinking about adding a little more power and the 8 3/4 makes me nervous.
67' charger 499 RB
10.57 at 127
[Re: Charger453]
#1634236
06/16/14 06:09 PM
06/16/14 06:09 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have been running one for a few years with no problems other than when I got it it had a lot of casting sand stuck up in the pinion area.
It has held up fine, my problem is ring and pinion life. I
"Just a Bracket car dressed up like a streetcar"
[Re: DoctorDiff]
#1634237
06/16/14 08:42 PM
06/16/14 08:42 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Mopar never made a steel 8.75" case, nor steel caps.
I stock a couple different 489 cases with FORGED STEEL caps.
http://www.doctordiff.com/8-3-4-nodular-iron-casting.html
This subject, Mopar making a "better" 8 3/4 center section for drag racing, came up in one the old Mopar sponsored Drag Seminars, Mr Hoover said there was no need as the stock 8 3/4 cases where all cast steel Maybe I heard him wrong, that was when the Ford 9 inch was coming into being popular with thier nodular iron center section being the trick hot set up of the week in some of the car magazine back then Now,if I can remember how to test cast grey iron compared to cast steel with a hammer and chisel or a hacksaw, I'll let everyone on here know what I find out
[Re: Just-a-dart]
#1634239
06/16/14 10:19 PM
06/16/14 10:19 PM
Quicktree
you will never solve that issue with an 8-3/4 with any power
