Page 3 of 3 1 2 3
Re: Which distributor is everyone's preference [Re: sunroofgtx] #1634125
06/16/14 05:45 PM
06/16/14 05:45 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Ignition box msd; distributor stock shift at 7000 rpm. Hasn't caused a problem yet.
Re: Which distributor is everyone's preference [Re: JACK1440] #1634126
06/16/14 05:52 PM
06/16/14 05:52 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
MP tach drive dist. Crane Box and coil, Firecore wires.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Which distributor is everyone's preference [Re: Hemi Allstate] #1634127
06/16/14 08:01 PM
06/16/14 08:01 PM
JCFcuda Offline
JCFcuda  Offline
Mallory Ignition Box - HyFire VIIS easy to set up,
Stock Dis, MSD crank trigger.
Re: Which distributor is everyone's preference [Re: Triple Threat] #1634128
06/17/14 11:07 AM
06/17/14 11:07 AM
an8sec70cuda Offline
I have an 11 year old MSD pro billet distributor on my hemi. The inside is crusty looking, but never had a problem w/ it. Recently switched to a crank trigger...runs the same. The rust evidently doesn't hurt anything.
For a crank trigger deal, you can run pretty much any distributor and be fine.
I have MSD 6al boxes on all our cars. I don't care for the MP boxes and the ridiculous claims made about the Rev-n-ator were enough to convince me never to buy one.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which distributor is everyone's preference [Re: JACK1440] #1634129
06/17/14 02:17 PM
06/17/14 02:17 PM
NC
440Jim Offline
440Jim  Offline
NC
Has anybody used one of the inexpensive ones on the market now?
At $55 for a new distributor with good features, somebody must have tried them.
Ebay link - 440 Mopar Distributor
• A billet of 6061 - T6 aluminum CNC is machined into a perfect housing for incredible strength, precision and looks.
• Sealed ball bearings, sintered bushing, 1/2 inch hardened steel shaft
• Extremely accurate magnetic pickup which never requires adjustment.
• Designed with a small base and cap to suit all makes and models.
• This is mainly used in high performance vehicles which have space limitations around the engine.
Re: Which distributor is everyone's preference [Re: 440Jim] #1634130
06/17/14 02:48 PM
06/17/14 02:48 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Looks like the same as the Pro-Comp one - I got one in a box - I used it for a month - yours for the shipping
Re: Which distributor is everyone's preference [Re: DoubleD] #1634131
06/17/14 05:33 PM
06/17/14 05:33 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
MP tach drive dist is my choise as they are relyebell ! Im not so inprest of what every one seam to go for as almost al parts are assembeld in Taiwan these days for more profit what ever they advertyse and brag about so the only thing i use from MSD is the coil as the Revenator works good whit that.
Re: Which distributor is everyone's preference [Re: 440Jim] #1634132
06/17/14 10:56 PM
06/17/14 10:56 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
yep, if you look back a page you'll even see my pic of my motor with one fitted. as I said in my post, it's a great dizzy but it's internal magnetic trigger is rubbish, but if you're using a crank trigger, these dizzys work well.
Re: Which distributor is everyone's preference [Re: bigdad] #1634133
06/18/14 01:55 AM
06/18/14 01:55 AM
I like and use the stock Mopar magnetic pickup distributors with vacume and mecahical advance. I weld the slots up to limit the mechanical advance to 18 to 20 crankshaft degrees , 9 to 10 distributor degrees, so I can set the initial timing at or cloes to 14 to 16 BTDC I buy the Mr Gasket Chevy distributor spring advance kit and use both of those skinny little short rascals I think the Mr G part # is 25B, if not let me know and I'll go out in the shop tomorrow and verify the correct part number for you
Re: Which distributor is everyone's preference [Re: rebel] #1634134
06/19/14 03:57 PM
06/19/14 03:57 PM
NC
440Jim Offline
440Jim  Offline
NC
When I first read your post I missed the connection to the ProComp distributor in the middle, I looked it over too quickly. I imagine most of these off brand ones are made in the same factory. Thanks for the feedback.
I used a stock distributor with the weights welded with my crank trigger for many years. But now I am waiting on a KB alumuminum block and their "low deck" still uses a RB distributor so I need to buy something. For $55 I could disable the mechanical advance for use with my crank trigger and MSD ignition box. New housing (CNC), new ball bearings, etc. and it clears the valve covers with Indy heads
Re: Which distributor is everyone's preference [Re: Cab_Burge] #1634135
06/19/14 04:06 PM
06/19/14 04:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The Mr.Gasket spring # for Chrysler electronic dist. Is #925B
Re: Which distributor is everyone's preference [Re: 440Jim] #1634136
06/19/14 05:15 PM
06/19/14 05:15 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
MSD for years now with no problems
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Which distributor is everyone's preference [Re: megajoltman] #1634137
06/19/14 06:18 PM
06/19/14 06:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have this dist sitting here.. I think its a MP part
and its pretty nice.. easy to set the advance on.. just
loosen a screw and slide the advance and tighten the
screw.. this one is new but I forgot where I got it from
Re: Which distributor is everyone's preference [Re: MR_P_BODY] #1634138
06/19/14 06:19 PM
06/19/14 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A close up of how you adjust the advance
Re: Which distributor is everyone's preference [Re: MR_P_BODY] #1634139
06/19/14 08:12 PM
06/19/14 08:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Factory stock elec dist. (most are free) with one tiny spring, all in when started, MSD 6 or 7 and right coil. Then worry about other things more important. All i used since 1974, still got the 7 box with the 5 pin hook up. So simple a cave man can use one.
Re: Which distributor is everyone's preference [Re: cudaman1969] #1634140
06/20/14 02:12 AM
06/20/14 02:12 AM
My MSD 404 C box quit at the MATS race three years ago, it was Sunday morning, I was the first car in the left lane for the first round of Pro and the box to a hike I had a spare MSD7C in the trailer that I could have swapped and bought back in but I figure it wasn't meant to be that day so I put in the trailer and towed it home 850 miles without a fisrt round win Nothing last forever, even the best parts die and wear out
Re: Which distributor is everyone's preference [Re: Cab_Burge] #1634141
06/20/14 12:26 PM
06/20/14 12:26 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Add me to the list still using the old MP tach drive dizzy. Still using the old mechanical SW tach, too, left over from the old factory race days.....
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Which distributor is everyone's preference [Re: Steve1118] #1634142
06/20/14 05:27 PM
06/20/14 05:27 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Same here and I'm not changing it..no reason to.
Nautilus Racing-
Re: Which distributor is everyone's preference [Re: bigdad] #1634143
06/21/14 09:31 AM
06/21/14 09:31 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I am building a spare stock distributor and am going to test it on the street with a Pertronics II inside against my current MP adjustable dist and stock mopar electronic ignition. A few years ago I took out my chrome ECU and installed a stock ECU from the early 70s and it ran I think better than the chrome box. So I have a stock real mopar ECU in there now.
Welded up the slots the other night. I still have have to fine tune the weld, won't know that until I get it in the car since I don't have a dist machine. I do have a spare sb sitting ready to run, I may use it to fine tune my mechanical advance?
Page 3 of 3 1 2 3
