Re: Doing away with ac on 383
[Re: Bayoulee]
#1633484
06/14/14 01:05 PM
06/14/14 01:05 PM
RapidRobert
If the thermal clutch fan is still working (engageing when hot) I would keep it & if it ain't working I would replace it with another MP thermal clutch fan & not go to electric. Yes get the Herbs kit Pynzo mentioned. Wouldn't hurt to k.i.s.s. and keep the same pulley ratios in there if the water pump impeller is still a 6 blader. I'd mockup & see if you could keep the same pulleys just use different grooves unless someone confirms that that will not work & that you do need non AC pulleys. Measure the diameter of the crank/wp pulleys you have now for reference then there's the depth issue for belt alignment
[Re: RapidRobert]
#1633485
06/14/14 02:27 PM
06/14/14 02:27 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
IIRC the wp pulley is a single belt that had an adjuster for it.Its pretty easy to change the WP pulley and the alt brackets.I used to run the AC pulley lower on y 440.Just changed the brackets and the WP pulley.Remember old BBs had an odd bolt pattern on the crank pulley.New will fit IIRc.Rocky
Chrysler Firepower
[Re: Bayoulee]
#1633487
06/15/14 01:34 PM
06/15/14 01:34 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
I had an A/C pulley setup on my 383 when I first got it. One of the previous owners had removed every bit of the a/c setup with the exception of the alternator bracket and pulleys. The belt system did not line up very well without the compressor and caused noisy belts and premature wear. This is why I suggested the non a/c alternator kit and different pulleys. The simple clean setup. Compare the depth of your existing wp pulley to this non a/c and you'll see what I mean about belt alignment. Also with the new kit you need to remove the inner alternator bracket held onto the side of the head w/ 2 bolts as the new pivot bolt threads directly into the head.
[Re: Pynzo]
#1633488
06/15/14 04:50 PM
06/15/14 04:50 PM
therocks
Niles , Ohio
Set of non AC pulleys in the last listing BB section for sale.They should be what you need.Rocky
Chrysler Firepower
[Re: Bayoulee]
#1633491
06/16/14 10:29 AM
06/16/14 10:29 AM
therocks
Niles , Ohio
IIRc the car dosent have AC.The motor he bought does.Thats why he wants to eliminate the AC stuff.Rocky
Chrysler Firepower
[Re: fastmark]
#1633494
06/17/14 01:22 AM
06/17/14 01:22 AM
RapidRobert
I just saw a pair of painted wp/crank pulleys in the FS section for $35. If they are the depth you need I'd be all over em at that price
[Re: Bayoulee]
#1633497
06/17/14 11:40 AM
06/17/14 11:40 AM
RapidRobert
It's on the last page (5) & the 5th post up from (including) the last one. It's a PS set so the crank pulley has 2 grooves which I believe you'll need being it's going into a Fury. Dont sweat the cav issue right now.
[Re: Bayoulee]
#1633499
06/17/14 12:02 PM
06/17/14 12:02 PM
RapidRobert
It's highly likely that these are a matched BB set with them both being painted & all & being offered together. Ask him If he had em on a BB with PS himself as he might just be flipping them & if so (he's used em) to give you first dibs on em all in the next email as they aint' gonna last long. I'd hate to direct you wrong but I have a real good feeling on this deal.
[Re: Bayoulee]
#1633500
06/17/14 12:09 PM
06/17/14 12:09 PM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
The wp will spin slower with this setup but not a problem w/o a/c. Most replacement pumps are 6 blade a/c nowadays, just one of the parts you're gonna want to change before firing up this motor as it does appear to be untouched. Timing chain/ gear set, oil pump, water pump, fuel pump, and heat riser at a minimum to get that motor to a good starting point. You can also eliminate the heat riser for better flow if reusing the ex manifolds.
[Re: Pynzo]
#1633501
06/17/14 01:14 PM
06/17/14 01:14 PM
therocks
Niles , Ohio
I ran a 4 pulley set on my 440 for years.It had a single pulley WP.My 65 had no ps though.IIRC the bottom 4 pulley was an AC car.If the bottom pulley is a later year you need to open one hole a bit as Ma used an odd pattern and you also have to line up all the holes on damper and pulley.The March pulleys we run come with an elongated hole to fit both.Rocky
Chrysler Firepower
