Dyno testing tomorrow, what will it make?
#1632987
06/13/14 01:14 AM
06/13/14 01:14 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
I'm getting ready to do some dyno testing and tuning on one of my 470 C.I. pump gas 440 motor tomorrow morning, 3.90 stroke with 4.375 bore. It has 9.64 to 1 compression with a set of Eddy RPM heads, the rockers are a set of Harland Sharp 1.54 to 1 ratio rollers. Eddy Performer RPM intake with a 1/2 thick phenolic spacer, 850 CFM Holley 4781-7 carb. It does have a set of 7.1 long rods and a set of forged KB Icon reverse dome pistons in it with almost no quench, .052 between the flat of the piston and the heads The cam is a Comp Cams XE275HL, the dyno is the famous central Oregon Studka dyno (2500 ft. above sea level) with all the latests calibration specs We got the motor mounted and fired up today, ran it long enough to set the timing at 34 BTDC and broke in the cam varying the load to help seat the rings by varying the RPM from 1500 loaded to 2500 with a small load on it, no WOT pulls today ( I had a Dr. Appointment also ) What say you on torque and HP? I'm hoping for 500 + on both HP and torque, actually expecting 550 HP and 570+ ft lbs on the torque, on Oregon non ethanol pump swill I'm planning on testing two different Holley 850 DP(1 4781-2 and the newer 4781-7) and two different heat range spark plugs, a set of Champoins RC9YC and a hotter set of the RC12YC to see which one the motor likes on the dyno I will use the wideban and jet both carbs. for best power and torque. Hoping on everything going well, if so I'll try and post some results tomorrow evening when I get back here Maybe I can learn how to scan and post copies of the dyno sheets also
Re: Dyno testing tomorrow, what will it make?
[Re: Cab_Burge]
#1632988
06/13/14 01:37 AM
06/13/14 01:37 AM
Posts: 5,164 CT
GTX MATT
CT
Hey Cab, what did the heads flow. I'm very interested in what you find on the plugs, and how easy it is to get those carbs dialed in as I am up in the air between an 800 and 850. Good luck
[Re: 451Cuda]
#1632991
06/13/14 04:03 AM
06/13/14 04:03 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Just a guess. Stock eddie heads? 498 h.p. 535 lb ft torque
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#1632992
06/13/14 06:15 AM
06/13/14 06:15 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
The cam IMO is abit small for the combo, I'll say 510-515hp & 530-540 lb. torque.
[Re: gregsdart]
#1632995
06/13/14 01:31 PM
06/13/14 01:31 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I'm guessing 535hp / 540tq.
2 kids and a dog
[Re: Cab_Burge]
#1632997
06/13/14 02:26 PM
06/13/14 02:26 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I am interested too, as this build is similar to my engine that is still on the stand. As already asked, what, if any mods to the Eddy heads were done? I guess 510 HP 525 tq. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: GTX MATT]
#1633000
06/14/14 01:51 PM
06/14/14 01:51 PM
Cab_Burge
What happened Cab?
The motor didn't make any where near what I expected The printer attached to the dyno was out of ink so the operator downloaded all the pulls to a thumb drive and took it home so he could send me the copys via E mail. He sent me a picture of one sheet he printed at home and of course I can't read it I ask him this morning to send me copys of all the front sheets, the torque and HP summary sheets, so I can look at all the reuslts to post them on here. I'm hoping he sends them to me this morning The motor started off making 500+ ft.bs from 2500 RPM to 5000 RPM and around 470 HP on the first couple of pulls to seat the rings, it was really fat(11.2 to 11.6 AFR) at WOT through the entire RPM range . We change the upper RPM limit to 5500 RPM and then to 6000 RPM finally. We leaned the first carb.(4781-7) down several times, 4 jets sizes on all four corners and I then opended up the high speed bleeds on it as well as leaned the idle mixture screws down quite a bit also. The motor liked leaner I change the plug heat range from a RC9YC to a new set of RC12YC, it liked that also, aluminum heads and 9.7 to 1 compression ratio so it will run on 87 octane regular No compression = no heat so the plugs needed to be hotter I changed the carb to another 850 D.P., 4881-2 I had and it made a little more power, not a bunch, but it was leaner(12.3 to 12.5) and more consistent on the WOT AFR all the way from 3000 to 6000 RPM which ended up making more HP and torque. I think we saw 512 HP and 550+ ft. lb on the gauges on the dyno, without the printed sheets I'm really just guessing though I'll try and post them as soon as I get them Dang baby cams don't work The car has power brakes hence the Comp Cams XE275 HL cam so I will live with the results The customer is thrilled with those reults,the motor idle at 12.+ inches of vacume at 1000 RPM I wish that I could have talk him into removing those dang power brakes so I could have put a little bigger and better cam in it, the motor has to have fuel and air to make power, more air, more power More to come shortly, hopefully
[Re: Cab_Burge]
#1633001
06/14/14 02:04 PM
06/14/14 02:04 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Your customer is happy, and you built 550 ft lbs of torque where it will do the most good! I look at that as a pretty big win, based on the fact that you got it from 87 octane? The expected Hp isn't that far above what you have either, If you tweak it and pick up a few more. Do you think retarding the cam might help?
[Re: gregsdart]
#1633002
06/14/14 02:32 PM
06/14/14 02:32 PM
Cab_Burge
Greg, I tested that motor with non ethanol 91 octane, not regular Sorry for the misleading comments on him being able to run the motor on regular He wanted a motor he can do burn outs in a 1969 Coronet super Bee That motor , with the proper torque converter, should shred his street tires As far as retarding the cam, all the Mopar motor I've dyno tested and done the testing at the track, didn't like the cams retarded That cam is ground on 110 LSA, I don't have the cam timing notes on that motor now but I think I put it in around 105 to 107 ATDC( 3 to 5 degrees advanced) on the intake lobes I'm anxious to see how it drives in the car I've had 446 and 452 C.I. iron headed pump gas motors( with bigger cams, similars size carbs and intakes) make more HP than this rascal did
[Re: joedust451]
#1633003
06/14/14 04:21 PM
06/14/14 04:21 PM
joedust451
super gas
super gas
Branson, Mo.
Looks like i got pretty close, Don't be disappointed in those #s cab, The torque is high & thats a plus right there, I'd rather give up 15-20 HP then lose 20ft. lbs torque, 12 inches vacuum is "dead on" for the XE274H series cam, The XE284H gives around 10 inches, Its worth about 15 or so more HP over the 274, But you tuned 40+ HP out of it with just tinkering & jetting, Thats an A+ right there
Cab, what was your final jetting & air bleeds on that 850?
It'll run great!!
[Re: Cab_Burge]
#1633004
06/14/14 04:29 PM
06/14/14 04:29 PM
joedust451
super gas
super gas
Branson, Mo.
Stock eddy heads are not magic really, they flow around 275-280, After i worked my 906s with bowl work & short turn radious, they flowed 265ish with "stock" size valves.
105 is just fine on that cam, My 284 was installed at 105.5
[Re: joedust451]
#1633005
06/15/14 02:01 PM
06/15/14 02:01 PM
Posts: 5,164 CT
GTX MATT
CT
Cab, do you think the dual plane intake made the carbs harder to get leaned out?
I said before I'm stuck between choosing and 800 and 850 for my car, and I've heard that the 850 can be troublesome/lack response.
[Re: GTX MATT]
#1633006
06/15/14 02:26 PM
06/15/14 02:26 PM
Cab_Burge
I have another 3.90 stroke 440 block pump gas motor I will test next month, if the money allows that On this one the RPM intake probally limits the peak HP RPM, I looked at the sheets the dyno operator sent me, there hard to read by E mail or Photo Bucket It looks like the motor made 506 HP at around 5700 RPM and 570 Ft. lbs at a RPM I can't read, I'm guessing between 4000 to 4500 RPM As far as the jetting on the 4781-2( the second carb. tested) I had 78 in the front with a 6.5 power valve and 86 in the rear with no power valve and no other mods. I'm aware of or did other than having the choke blade removed. On the first Carb, 4781-7 I did open up the H.S. bleeds to right at .028 or .031, CRS It ended up with 76 jets in the front and 74 in the back with power valves in both metering blocks like stock I think thats the jetting and H.S. bleed sizes, CRS again It really suprised me when the earlier carb did better with stock jetting than the later carb. did I guess that is why we test I will switch manifolds on the next motor, take off the RPM and put on a either a Mopar M1 single plane or my old favorite, the Weiand Team G single plane I'm hoping to get some printed copies of those results soon so I can read all the data instead of parts of it All in all it was a good day, nothing broke and it made 40 more HP than it started out with BTW, making the AFR leaner did reduce the torque but it improved the HP, at the track by using a wide ban gets the same results Leaner is faster than richer. We don't race dyno ,do we My old M.W.stocker out ran the other cars in the same class that had hot spark plugs and a rich mixtture Test, test and test some more, the spark plug and time slip is your freind
